C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
MAP Sensor
Old Oct 6, 2010 | 03:57 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Default MAP Sensor
What is the bar rating on the MAP sensor for the 1593 E-Force?
What does that translate to in the MAP Sensor Scaler of the tune.
Elmer
Old Oct 6, 2010 | 04:46 PM
yonson's Avatar
yonson
It's a 2 Bar Ford sensor.
Here's the parameters for use with HP Tuners
MAP Sensor Linear use 223.43
MAP Sensor Offset use -7.88
IAT sensor Cal (make sure the labels match as well)
Labels 563 715 918 1191 1564 2080 2804 3273 3837 4515 5337 6335 7556 9056 10908 13216 16092 19696 24239 30000 37352 46797 59016 74940 95851 123485 160313 209816 276959 368896 496051 673787 925021
Temp. 150.00 140.00 130.00 120.00 110.00 100.00 90.00 85.00 80.00 75.00 70.00 65.00 60.00 55.00 50.00 45.00 40.00 35.00 30.00 25.00 20.00 15.00 10.00 5.00 0.00 -5.00 -10.00 -15.00 -20.00 -25.00 -30.00 -35.00 -40.00
If your IAT still reads off you will need to change the IAT2 Cal too
Temp. 302.0 284.0 266.0 248.0 230.0 212.0 194.0 185.0 176.0 167.0 158.0 149.0 140.0 131.0 122.0 113.0 104.0 95.0 86.0 77.0 68.0 59.0 50.0 41.0 32.0 23.0 14.0 5.0 -4.0 -13.0 -22.0 -31.0 -40.0
Old Oct 6, 2010 | 06:00 PM
eboggs_jkvl
Moderator emeritus
Thanks for the information. I pretty much match up exactly to your data.
Elmer
Old Oct 6, 2010 | 07:19 PM
eboggs_jkvl
Moderator emeritus
One more thing:
1 bar is 94.429
2 bar is 188.00
so why is our 2 bar at 223.43? That is almost a 2.5 BAR setting.
Elmer
Old Oct 7, 2010 | 05:58 PM
yonson's Avatar
yonson
It is the same TMAP sensor that is used on the 2003/2004 Ford Mustang Cobra, the value that is used is what the sensor would read at 5 volts, not what it's actually rated for.
Old Oct 7, 2010 | 06:51 PM
backchannel's Avatar
backchannel
Originally Posted by eboggs_jkvl
One more thing:
1 bar is 94.429
2 bar is 188.00
Elmer
1 bar = 101.3 kpa
Old Oct 7, 2010 | 11:07 PM
eboggs_jkvl
Moderator emeritus
Originally Posted by backchannel
1 bar = 101.3 kpa
From EFILive MAP Sensor Scale entry:
Used to scale the MAP sensor voltage output into a kPa/psi value.
1bar sensors are typically - 94.429688
2bar sensors are typically - 188.000
Not trying to be argumentative.
Elmer
Old Oct 8, 2010 | 11:16 AM
eboggs_jkvl
Moderator emeritus
They are giving u scaling to use. My 2 bar scaling is 200 kpa +10.34 offset. Here is a little more accurate info
1 bar = 100 kpa = 14.5 psi
101.3 kpa = 14.7 psi = sea level atmosphere
We live metric here
OK, that makes more sense. At least now my math works out in my mind.
Thanks,
Elmer
To MAP Sensor
