C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
LS2 procharger ??
Old Nov 22, 2010 | 03:30 PM
BELLMAN's Avatar
BELLMAN
Default LS2 procharger ??
I have a procharger setup on my '06. Recently ran on dyno and came up with 477RWHP. Very conservative setup. Want to know where I can go from here with stock motor?
pulley has stamped 4.63 on it.
What will this motor/fuel system support safely ?
Thanks in advance.
Old Nov 22, 2010 | 04:11 PM
BELLMAN's Avatar
BELLMAN
FYI, I have searched and read and found a lot of old posts. Looking for some current examples/information. Thanks.
Old Nov 22, 2010 | 04:44 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
You should be well over 500 RWHP easy. What was the boost at redline, final timing and AFR?
Old Nov 22, 2010 | 05:03 PM
BELLMAN's Avatar
BELLMAN
We just ran as a baseline. A/F was 11.2, don't know timing or boost. A full tune is next. #'s were below my expectations and wanted some ideas on where to go from here. Sorry for the lack of information.
Old Nov 22, 2010 | 06:12 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
what procharger do you have on there? p1sc d1sc f1c f1r f1a f2
Old Nov 22, 2010 | 06:38 PM
BELLMAN's Avatar
BELLMAN
p1sc
Old Nov 22, 2010 | 06:47 PM
saplumr's Avatar
saplumr
A 4.10 pulley should put you close to 10psi w/meth you should realistically be around 560whp+ if you have headers.
Old Nov 22, 2010 | 09:23 PM
Silverboost's Avatar
Silverboost
My 05 a4 put down 552 rwhp with a 4.25 pulley which is about 9lbs. I have headers and a dallas perfromance air intake. You will need more fuel both larger injectors and a bigger fuel pump or boost a pump. I put a z06 pump in mine and it is sill loosing fuel pressure above 6300 rpm. Your current set up should be about 500 ish give or take hp with a good tune.
Old Nov 22, 2010 | 09:52 PM
DaytonaFIC6's Avatar
DaytonaFIC6
I stepped down to a 4.25" pulley on mine with 42 lb/hr injectors and a stock pump. My injectors are at 98% now. Needless to say I need a little more fuel. My car made 505 on a dynojet that is notoriously stingy. If I were you I would get some 60 lb/hr injectors a BAP or fuel pump and pulley down to at least 4.25 maybe a little smaller and get a tune. Go ahead and add a 2 bar map sensor while you are at it. The factory GM unit from the cobalt SS is a direct plug in.
Old Nov 23, 2010 | 09:03 AM
BELLMAN's Avatar
BELLMAN
Thanks for the insight. working on a plan now.
Old Nov 24, 2010 | 04:12 PM
playtoy's Avatar
playtoy
Just drop it off at Dallas Performance. They will fix you up. They managed to squeeze 700 out of my stock LS2 block with a D1SC, Cam, Headers and Meth
To LS2 procharger ??
