Only the mods in the bio with a 3in. pulley and fast65 injectors. Some It had 584HP on a Mustang Dyno. traction problem but not to bad. The noise is much better, not sure why. We didn't do anything.
Well that should silence a naysayer or two for a while....one in particular comes to mind. Guess you overcame the....
- "Heat Soak Pig"
- "Can't use all of that torque that early"
- "All of that extra weight"
- "Blower is maxed out"
- "Loss of boost pressure during shifts"
...and whatever else I may have missed recently.
Congrats
- "Heat Soak Pig"
Congrats
Thank you, And it has a soft tune. They only set the timing at 14 deg. and it is rich. Not sure how much it will pick up with a cleaner tune? I should have that done this week. Going back to the track next weekend Need 10.3
Did I understand that this was your first trip to the 1/4? Not too bad for a newb! To sum it up...
You have a 2011 Grandsport Coupe with A6
You have ARH headers w/cats thru NPPs
You have Nitto NT05s
You have the LG Motorsports G6XB complete blower cam kit
You have the Edelbrock 1591 supercharger
You have upgraded from 52lb to 65lb injectors
You changed from the 3.5" to the 3" pulley
You upgraded the fuel flow to feed both rails
"The Tuning School" tuned your car with a 584rwhp final number on a conservative tune
You are running 14 degrees up top with an AFR of 11.7-ish
Did I miss anything?
LMAO you know my car better than me! . That is it. I am going back to the Tuning School today @ noon, they are going to tighten it up. I will post the new sheet later.
Hats off to Ian and Bob. I think I need to bug them for some tips on my tune now that they have seen how well your car works.
