C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
How does supercharging affect target DCR?
Old Dec 17, 2010 | 02:02 PM
Neil B's Avatar
Neil B
Default How does supercharging affect target DCR?
For the sake of argument let's say the target pump-gas DCR is 8.5:1. So we cam the car accordingly based on static CR, IVC, stroke, etc. Do the same rules apply for a supercharged combo? Is that why popular thinking with a 9.5:1 blower motor has most guys camming it with about 220/230@.050 duration (to keep the DCR up with the lowered compression)? Is there any affect at all to target DCR when boost and meth injection are part of the equation?
Old Dec 18, 2010 | 08:06 PM
Skunkworks's Avatar
Skunkworks
A simple answer is static CR * PR (pressure ratio) will give dynamic CR.
PR = (boost / 14.7) + 1
This is the very simple way to look at it and not complete picture.
Mike
Old Dec 18, 2010 | 08:50 PM
old motorhead's Avatar
old motorhead
I've been seeing "DCR" mentioned for quite awhile now. Not wanting to hijack this thread, but can someone direct me to dumbed down directions on how this is calculated?
Old Dec 18, 2010 | 08:56 PM
Skunkworks's Avatar
Skunkworks
That's what I posted but probably poor explanation.
Your SCR (static CR) is your compression ratio with factory or mild cam. DCR is what it is with boost.
Mike
EDIT
DCR = SCR * PR
Old Dec 18, 2010 | 08:58 PM
old motorhead
Mike
I thought DCR took into effect cam timing?
Old Dec 18, 2010 | 09:00 PM
Skunkworks's Avatar
Skunkworks
Yes it does, but with stock cam above is a simple way to get there with boost. It gets complicated with big cams, so that's why I posted simple version.
Mike
Old Dec 18, 2010 | 10:06 PM
old motorhead
Mike
If I wanted to dealve into it a little deeper, is there a source that might make it understandable to a simple mind?
Old Dec 19, 2010 | 11:46 AM
j_digi454's Avatar
j_digi454
I just bought the book "Supercharged" by Corky Bell on Amazon for about $23 and it has all this info and a lot of other good info in pretty simple form. It was a recommendation by Forum member PowerLabs.
Old Dec 19, 2010 | 02:08 PM
Neil B's Avatar
Neil B
Mike
EDIT
DCR = SCR * PR
Not sure I'm following what you're saying. DCR (Dynamic Compression Ratio) is the measure of the 'actual' dynamic compression ratio the engine experiences while running. DCR applies to normally aspirated engines as well and it has everything to do with the effects of cam timing on static compression ratio. A motor with 11:1 SCR can have 8:1 DCR. So, if the optimal DCR for a pump gas N/A engine is 8.5:1 to stay out of detonation, how does the pressure ratio associated with adding boost affect that optimal DCR?
Old Dec 19, 2010 | 02:10 PM
Neil B's Avatar
Neil B
Pat Kelley's DCR calculator is a great resource....
http://www.empirenet.com/pkelley2/DynamicCR.html
Old Dec 19, 2010 | 07:03 PM
old motorhead
Good stuff....thanks
Old Dec 19, 2010 | 08:04 PM
Skunkworks's Avatar
Skunkworks
Maybe this will help http://forums.corvetteforum.com/1574681388-post7.html . Some people use the term DCR, ECR, FCR... I thought this is what your after since your in FI section.
Mike
Old Dec 20, 2010 | 08:44 AM
old motorhead
Pat G. specced me a blower cam a few months back. It was for my iron block forged 6.0L in my GMC daily driver. Maggie blower at 8psi. Specs were 214/224 116LSA. Static c/r is 10.5 and he calculated the dcr at 8.15. He also did the cam in my vette 219/231 .607/.617 115lsa. I looked a little last nite, but couldn't find the recommendation sheet that shows the exact timing events and dcr on that set up.
Old Dec 22, 2010 | 12:22 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
The DCR on a boosted engine is a lot higher, which is why we pull so much timing, and/or add octane and/or add meth compared to the same engine NA.
When I was designing my setup I made a spreadsheet that incorporated a DCR calculator along with the timing and octane formulas from Kenne-Bell's website. It allowed me to see (at a rule-of-thumb level) the interactions between boost level, SCR, cam timing, ignition timing, and octane requirements. Once I thought I had what I wanted I ran the resulting cam and SCR by some genuine experts and they seemed to think it was pretty much spot-on for my application. But it's not running yet so who knows?
To How does supercharging affect target DCR?
