C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Horn
Old Dec 27, 2010 | 06:02 PM
ShowcaseC6's Avatar
ShowcaseC6
St. Jude Donor '10
Default Horn
Has anyone with a S/C car figured out the fix to this yet? Tired of my car sounding like a muppet every time I lock the car or try to honk someone thats looking to run me over.
Old Dec 27, 2010 | 06:15 PM
Motorhead-47's Avatar
Motorhead-47
Make sure the two horns are touching absolutely nothing but the bracket they are mounted to and make sure that you have good solid grounds.
Old Dec 27, 2010 | 06:48 PM
MARSC6's Avatar
MARSC6
The SC shouldn't have anything to do with the horn not working properly.
Old Dec 27, 2010 | 06:50 PM
Motorhead-47
Horns usually have to be relocated during a supercharger install.
Old Dec 27, 2010 | 06:55 PM
MARSC6's Avatar
MARSC6
I had to relocate mine but that didn't change the sound. There is some other problem. Maybe a loose connector or a bad horn.
Old Dec 27, 2010 | 07:00 PM
Motorhead-47
As mentioned in post #2 above, make sure the horns are touching nothing but the bracket they are attached to when you relocate them and that the relocated mount has a good ground to chassis.
Old Dec 27, 2010 | 09:32 PM
playtoy's Avatar
playtoy
Make sure you pluged both of them in
Old Dec 27, 2010 | 09:46 PM
yonson's Avatar
yonson
If the new bracket is coated grind off the coating where it mounts on both ends...
To Horn
