C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
best pump ??
Old Jan 9, 2011 | 10:51 PM
LSOHOLIC's Avatar
LSOHOLIC
Default best pump ??
Looking for the best/economical fuel pump for a stand alone nitrous fuel system ?? Looking to spray in the 100-200 range.
Thanks....
O, and regulator. Thanks..
Old Jan 10, 2011 | 12:29 AM
TRINIC5's Avatar
TRINIC5
Thanks....
When doing a stand alone system you don't need a high pressure pump, its simple you can buy a regular holley pump and a regular regulator to mantain 6 psi to the gas senonoid.
Old Jan 10, 2011 | 12:38 AM
LSOHOLIC's Avatar
LSOHOLIC
So if I was going to use the factory system and come off of the rail I'd regulate it down to carb. fuel presurre levels ?? Haha.. Damn, I'm making this harder than it needs to be.
Old Jan 10, 2011 | 01:18 AM
lockman's Avatar
lockman
if you not looking to be over 600 total wheel horsepower you won't need a stand alone fuel system. your stock pump will handle it.
Old Jan 10, 2011 | 01:23 AM
LSOHOLIC's Avatar
LSOHOLIC
yeah, I'm making roughly 500-520ish at the flywheel now so... And I'm looking to spray 100-200, but thanks for the heads up.
Old Jan 11, 2011 | 12:19 AM
LSOHOLIC's Avatar
LSOHOLIC
Did a little research and I do need a high pressure fuel pump for the stand alone. Just FYI, haha.. But I'm still looking for a recomendations for an economical choice that will git it done. Thanks..
Old Jan 11, 2011 | 12:39 AM
rattt g's Avatar
rattt g
don't blow the poor guy up mario if he is running a efi plate
he needs a pres pump
Old Jan 11, 2011 | 08:39 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
he can use carb fuel jets
Old Jan 11, 2011 | 09:20 AM
TRINIC5's Avatar
TRINIC5
Tell them its all about the jets used/
Old Jan 11, 2011 | 09:22 AM
TRINIC5's Avatar
TRINIC5
As an experienced nitrous man I thought you knew its all about the jets and the system, he said stand alone which can be a carb system and it will work pefect.
Old Jan 11, 2011 | 09:42 AM
rattt g's Avatar
rattt g
a plate designed to flow at let's say 50 psi
will not have the same atomization at 6 psi
Old Jan 11, 2011 | 10:27 AM
LSOHOLIC's Avatar
LSOHOLIC
I'm using a nitrous outlet single nozzle set up, if that helps(and yes its an EFI system). And I've decided to do a stand alone fuel system for saftey and sanity. With a 150 shot I will exceed my in tank pump limits even with a hotwire/BAP setup. I'm roughly at 550ish at the flywheel so another 150ish will push the pump beyond its limits, is what I've been told. Or there close to it.
So I'm looking for info on a pump and regulator for a stand alone system. Thanks
Old Jan 11, 2011 | 10:51 AM
LSOHOLIC's Avatar
LSOHOLIC
And just FYI, some of you may know but the C5Z pump is the same pump as the C6 standard pump. Thought I would say that since I'm in the C6 forum section. But as you all probably know, late 03' and on was the saddle tank top mount C6 fuel system design. Again thanks
To best pump ??
