C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
bap or not?
Old Feb 16, 2011 | 01:13 PM
kboboz71's Avatar
kboboz71
Default bap or not?
Hey guys, im debating on what to do for my setup. I've got an 06 c6 ls2 with h/c/I/e and a few other mods. Its making right at 500rwhp now and im fixing to install a dry nitrous setup on it and am trying to figure out what to do about fuel... its got inj. So im good there. I've been told to just get a bap and ill b good.. is this true? Ill b spraying up to a 150rwhp shot. Thanks for any help
Old Feb 16, 2011 | 02:23 PM
lockman's Avatar
lockman
yes a bap will work but I would do a stand alone fuel tank that way you can put race fuel in there a bap is more like a bandaid and not a very good one at that. there are many people that blow fuses with them and are left stranded. but it's up to you really.
Old Feb 16, 2011 | 02:44 PM
kboboz71's Avatar
kboboz71
So how am I supposed to wire it up or should I say how would it work? Aren't they boost referenced? And what brand should I get.
Old Feb 16, 2011 | 03:59 PM
White_Lightning's Avatar
White_Lightning
or do a 150 wet and dont worry about screwing with the rest of the fuel system.
Old Feb 16, 2011 | 05:39 PM
kboboz71's Avatar
kboboz71
Its too late. Already have the dry kit..
Old Feb 16, 2011 | 06:51 PM
White_Lightning
it's never to late.. Sell it and get a Nitrous outlet Wet kit
Old Feb 17, 2011 | 09:42 AM
lockman's Avatar
lockman
it's not hard to switch it to wet either but that won't solve the problem if your over 600 hp at the wheels the stock pump will not support it. wet or dry. but a wet kit just has a fuel cylenoid (SP) and the tip is different if you do the tip if you use a plate it should already be set up to accept both fuel and nitrous. from everything I've read the easiset it a bap but not the most reliable a in tank fuel pump is a good solution to me the best is a stand alone fuel tank to put race gas in for the nitrous when it kicks in
Old Feb 17, 2011 | 10:06 AM
White_Lightning
how do you figure.. i made 654/700 on bottle.. AF was perfect.. injector cycle was no where NEAR max.. STOCK fuel ls3 with a NO wet kit.
To bap or not?
