C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Gauge install question
Old Feb 21, 2011 | 07:30 PM
sea six's Avatar
sea six
Default Gauge install question
What is the best place to penetrate the firewall to run wires to a pod mounted on the A Pillar. Need to run wide-ban O2 and boost wires. While you are at it does the A pillar just pull off?
Rod
Old Feb 21, 2011 | 07:50 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Rod
I normally go right behind the dead pedal. No need to pull off the A pillar, The guage panel mounts on top of the orrigional panel.
Old Feb 21, 2011 | 08:00 PM
sea six's Avatar
sea six
Don't you need to access behind it to run wires? Just asking, thanks for any help. Also do you know were to get the power for the lights? Which fuse #.
Old Feb 21, 2011 | 10:40 PM
MARSC6's Avatar
MARSC6
I used an add-a-circuit on the heated seat fuse in the passenger footwell for power. To get through the firewall a poked a hole in the large grommet behind the battery.
The A-pillar pulls off. Before you remove it the small panel below it has to be removed. When removing the small panel pull out on the top then slide up. Then grab the a-pillar from the top and pull straight out. Its held on by a couple tabs and some velcro at the corner where it wraps around towards the front window.
Old Feb 22, 2011 | 03:39 PM
04 c5 vert's Avatar
04 c5 vert
.Remove the dead pedal with a 10mm socket and pull the carpet back.i drilled a hole about 7/8 of an inch right below the hood release cables and used a coat hanger to fish the 02 sensor wires it through the fire wall.
Old Feb 22, 2011 | 11:09 PM
Streetk14's Avatar
Streetk14
Everything you need to know: http://www.aacorvette.com/pdf/aa_c6_...structions.pdf
Old Feb 23, 2011 | 05:17 PM
sea six's Avatar
sea six
Originally Posted by Streetk14
Yes it is, thank you
Old Feb 24, 2011 | 11:32 AM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
Great write up
What gauges are you going with? I was thinking about adding Defi racer boost and fuel pressure.
To Gauge install question
