C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Windshield Washer Relocation Kit?
Old Mar 28, 2011 | 02:13 AM
Adis's Avatar
Adis
Default Windshield Washer Relocation Kit?
With a meth kit using the washer fluid tank, I was wondering if anybody makes a kit that will relocte a washer tank/pump to somewhere else in the engine bay? With the meth system using the sensor, is it even possible/easy to set up another pump for washer fluid that will run off the steering column controls. I realize the washer fluid tank wouldn't have the low fluid sensor, but I live in a very dusty place and would like to have the ability to clean off my windshield.
Old Mar 28, 2011 | 07:48 AM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
I left the lines to my WW sprayers attached so I can still clean the windshield. Since WW is 30-40% meth by weight spraying 100% meth on the windshield shouldn't be a problem, in fact I bet it would do a better job because it will evaporate faster.
Old Mar 28, 2011 | 08:13 AM
MARSC6's Avatar
MARSC6
Just as long as the car in front of you doesn't throw a cigarette out the window.
Old Mar 28, 2011 | 09:23 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
just add WW fluid in there and get it retuned. may be leaving 10-15hp on the table, but your windshield will be clean..
Old Mar 28, 2011 | 09:31 AM
SinisterC6's Avatar
SinisterC6
Speedy
Not recommended if your on a meth dependent tine running more boost, but a viable option for those just using meth injection to cool down IATs.
Old Mar 28, 2011 | 09:54 AM
carlrx7's Avatar
carlrx7
Some WW is still 40%, bigger jet or go dual. problem i see is getting WW with the same Meth content consistently. better start buying by the pallet!
-Carl
Old Mar 29, 2011 | 05:51 AM
Adis's Avatar
Adis
Yeah, I thought as much. I use laboratory-grade meth that I buy at a chemist's supply shop. I don't think it would be safe to be spraying pure methyl alcohol on my windows. I'll post in the tech forum and see if anybody has done a WW relocation. Thanks
Old Mar 29, 2011 | 07:12 AM
flyinmedic's Avatar
flyinmedic
PM WhiteLightning on the board,he is a friend of mine and his tuner just did something like this. He added a WW resevoir up front by the intercooler.
Here is his build thread, look at the pics towards the bottom of his post. You can see what they did
http://forums.corvetteforum.com/c6-f...-ls3-d1sc.html
Old Mar 30, 2011 | 11:58 AM
Adis's Avatar
Adis
Thx Flyinmedic, will do!
Old Mar 30, 2011 | 12:04 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
It's actually pretty hard to find WW fluid with even 30% meth in it here in TX. There is no call for -40 degree WW fluid here. Straight meth mang.
UPP does a WW tank relocation as part of their TT kit. May want to hit them up too.
Old Mar 30, 2011 | 04:05 PM
Adis's Avatar
Adis
Alky Systems is gonna hook me up! THanks for the replies everybody.
To Windshield Washer Relocation Kit?
