C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Halon systems?...
Old Mar 28, 2011 | 01:02 PM
DSteck's Avatar
DSteck
Default Halon systems?...
Anybody here have a nice halon system set up in their car? After a buddy's UGR TT Viper almost went up in flames from an oil line that leaked... I really want to get a halon system for when my TT project is done. I'm just looking to see what kits people have done, and what your impression was.
So... if you've done a halon system, share your experience!
Old Mar 28, 2011 | 04:52 PM
joe11204's Avatar
joe11204
Procharged F1X 7.18 @ 197
St. Jude Donor '09-'10-'11
Halon or FE-36 will be a great safety feature to add to your car. However, I think that as of Jan 1 2008, Halon is no longer approved by SFI. Don't know if your car is getting certified for racing.
I am using a Stroud Safety Fire Systems #877-9352 10 pound system.
The SFI 17.1 spec has a list of approved systems.
Old Mar 29, 2011 | 08:23 AM
chuntington101's Avatar
chuntington101
I was under the impresion that Halon is danergous and has been band from fire equipment? You would be better off with a foam or dry powder setup i would guess!
Chris.
Old Mar 29, 2011 | 08:39 AM
Mr.Big's Avatar
Mr.Big
The best on the market imho
see link:
http://www.safecraft.com/
Old Mar 29, 2011 | 08:21 PM
atomicfusion's Avatar
atomicfusion
I too am using a Stroud safty system with custom bent lines and nozzle placement. I would tell you that if you ever need it, you will be happy you have it. From someone that has had turbo cars for a while I will tell you that you should always have a fire extinquisher handy if not a fire system. Turbos get hot and stuff melts and some things can combust.
Old Mar 29, 2011 | 08:52 PM
rattt g's Avatar
rattt g
i think halon is baned, you can not even have them refilled anymore
Old Mar 29, 2011 | 09:16 PM
DSteck's Avatar
DSteck
Things getting hot is exactly why I want a supression system. I'll check out the stroud equipment. Thanks!
Old Mar 30, 2011 | 08:38 PM
NiceTry's Avatar
NiceTry
Two things i would never do to a street car because one done right doesn't need them .... a heavy *** iron block and a fire suppression system.
Old Mar 30, 2011 | 08:42 PM
atomicfusion
Yeah, you are probably right... what the hell do I know?
Old Mar 30, 2011 | 08:57 PM
flyinmedic's Avatar
flyinmedic
That's what people usually say when they can't afford a build of the caliber that requires those things.
Old Mar 30, 2011 | 10:16 PM
MomentumAutosports's Avatar
0MomentumAutosports
Former Vendor
We run safecraft stuff on our road race cars.
IMO, its not needed on a street car. I would however recommend a hand fire extinguisher on a turbo car or a car with modified fuel systems etc. 90% of fuel systems I see on high power street cars are not really designed great.
I have installed a full fire system in a street car before though. if done carefully, you will never see it ('cept the bottle).
Old Mar 31, 2011 | 08:49 AM
DSteck's Avatar
DSteck
I'm glad you think my iron block is dumb. Maybe you want to give me the extra $3000 for an RHS block. Do you have any posts where you aren't running your mouth and bagging on what other people do?
I've thought about just an extinguisher, mostly because they are cheaper, but the thought of pushing an "oh sh*t" button and drowning the engine bay with suppressant gives me an extra warm fuzzy.
Old Mar 31, 2011 | 10:00 AM
0MomentumAutosports
Former Vendor
Another tidbit is that is it not that easy. You have to arm the system by removing two pins, one at the bottle and one a the button. Theoretically you dont have to run these, but it is only a matter of time before it gets accidentally pushed!
Old Apr 4, 2011 | 05:12 PM
NiceTry's Avatar
NiceTry
I never said it was "dumb" it just isn't needed unless you are trying to set the world on fire, like say Mr Atomic and run 8.xx. In all the Motor Trend shoot outs, Car and Driver shootouts etc etc I have attended none of our cars or LPE's cars etc ever had an iron block.... but hey what do they know right? Six bolt heads cool? Yeah kinda, but needed for the power your turbos will make? Nope, not if it is tuned right and even then why was RC's car lifting heads with his 6 bolt block/heads? Because of a ****ty tune. I'll be the first to tell you I've trashed motors before, anyone that says they haven't is a liar, hell I melted pistons at an event for a Car & Driver shoot making over 1k rwhp... lift the heads? not even close..... A sleeved ls2 or ls7 block with good caps will support enough power that any TRUE street car will make.
Old Apr 4, 2011 | 05:19 PM
NiceTry's Avatar
NiceTry
I personally wouldn't consider your car a true street car.... but it's all in the eye of the beholder right? Very well built and fast though? Yes
Just like i wouldn't consider this a true street car
http://www.lingenfelter.com/LPEforum...read.php?t=773
Even though it has A/C, a stereo, and three pedals.... oh and an aluminum block......
Old Apr 4, 2011 | 05:31 PM
NiceTry's Avatar
NiceTry
Or because they have built enough of them to know what works best....
Old Apr 4, 2011 | 05:43 PM
JMBLOWNWS6's Avatar
JMBLOWNWS6
LOL What do you know? Like you where the lead tech at MTI or something
To Halon systems?...
Old Apr 6, 2011 | 10:55 AM
Rosspbig's Avatar
Rosspbig
Dont listen to this guy. A fire system is a good idea for any turbo /high horsepower car. I have seen many highly modified turbo street and race cars go up in flames in a hurry. Its like a roll bar, helmet, or HANS device. Just added safety.
Old Apr 6, 2011 | 12:51 PM
DSteck's Avatar
DSteck
An iron block was significantly cheaper considering I sold my LS7. That, and that alone, was the deciding factor. So how about you post something pertinent... or shut up.
This engine is going to see spray on top of boost eventually. I'm not worried about the tune because I'm doing it.
Or an airbag. You hope it never gets used, but when it does, you're glad it's there.
Old Apr 6, 2011 | 01:05 PM
0MomentumAutosports
Former Vendor
Dsteck-
I would recommend reading the SCCA rules regarding the systems installation. Ive seen systems installed poorly enough that they would do very little even used.
Minimum nozzles, imo:
1) engine bay, 180*
2) driver, 120*
3) fuel cell/tank, 180*
if you want to see what it looks like when you pull it, ill get the video up of my losing a motor @ NJ.
edit: http://www.grand-am.com/multimedia/v...p.cfm?mid=1693
need to post my incar, but by looking at the window you can guess what it looked like. BUmmer too, we ran down Rousch and had a shot at a podium
