C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Write up for meth install
Old Apr 5, 2011 | 02:12 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Yea you need to make sure that the dial is set right. If the pump works when the test button is pushed but not when you go into boost that is the first place to look.
Old Apr 5, 2011 | 03:21 PM
Robls6's Avatar
Robls6
Thanks alot!
Old Apr 5, 2011 | 07:31 PM
Slo-Poc's Avatar
Slo-Poc
On the a&s kit (08 ls3) can i put the meth nozzel in the rubber coupler after the maf. It seems like the only place to put it. Also can someone show me a pic of their a&s kit with the iat sensor and maf moved....
This is what im talking about with the rubber coupler vvvvvvv
Old Apr 5, 2011 | 09:51 PM
Res1cue's Avatar
Res1cue
Snow Performance has a solution for this.
http://www.snowperformance.net/product.php?pk=53
I am SD Tune so I have removed the MAF. My nozzles are mounted in the sides of the air pipe about 5 inches after the intercooler.
Old Apr 6, 2011 | 07:44 PM
Slo-Poc's Avatar
Slo-Poc
Can I run the meth there with out any problem?
Old Apr 6, 2011 | 07:49 PM
Robls6's Avatar
Robls6
Default Alky control kit doesn't work
I installed an Alky kit last week on my C6. Everything went well, and it works when I hit the "test" button on the controller, but when driving and getting into boost nothing happens. I tried adjusting the "turn on" setpoint to the lowest setting, and still nothing. Any suggestions on where to start. I am very confident everything is hooked up properly.
Old Apr 6, 2011 | 08:46 PM
5 Liter Eater
St. Jude Donor '11
Sounds like the MAP output is not making it to the PAC. Check that the correct wire from the MAP is going to the PAC. Check that the voltage the MAP is putting out is getting to the PAC.
