C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
New D1 blower alignment Problem
Old Apr 9, 2011 | 05:53 PM
crownu2's Avatar
crownu2
Default New D1 blower alignment Problem
Ok, put the D1 procharger on my z06 and as we were doing a dyno pull the blower belt came off as if the blower pulley is off a Rib. I lasered the pulleys and the Procharger is off a rib ..Now how do I fix that? well I thought of getting two new spacers from Procharger, shorter ones that is, or I can put the pulley on a lathe and take a 3/16 off the back of it and it should bring it closer to the motor, or I'm thinking of flipping the pulley over. I have heard sometimes that Procharger sends them out backwards from the factory...Not sure if that's true or not, but I'm going to try and flip the pulley (turn it over) before I take any material off the pulleys shaft or mating surface.
Does anybody have any better ideas before I do one of those three things? Has anyone ever heard of this happening before, as far as alignment problems?
Also, keep in mind, the belt started giving us a problem in the third pull, the first two the belt was fine.
Old Apr 10, 2011 | 05:13 PM
crownu2's Avatar
crownu2
Any one have any Ideas to the above??
Old Apr 10, 2011 | 07:22 PM
RMS-MAN's Avatar
RMS-MAN
You need to adjust the alignment thru the spacers. ie-Add washers, remove material from spacers, etc. Use the laser tool and get everything lined up with the crank pulley and you should be back in business. Working to get belts lined up is nothing new in the world of installing S/C so don't feel bad.
Old Apr 10, 2011 | 09:05 PM
Blown_2001Z06's Avatar
Blown_2001Z06
I've always had good luck making sure the numbers stamped on the pulley face the back of the car. How is yours setup?
Old Apr 10, 2011 | 10:02 PM
RMS-MAN's Avatar
RMS-MAN
I'm not sure about which way the #'s are facing, but it should be pretty obvious when you slide it on the shaft and see if it lines up right or not. Seems like the #'s are usually facing the blower where you can't read them.
Old Apr 10, 2011 | 10:11 PM
crownu2's Avatar
crownu2
They face the back of the Z06... thank you
Old Apr 10, 2011 | 10:19 PM
crownu2's Avatar
crownu2
Thank you so much, I thought i was on the right track, but theres alway some one out there with better Ideas like your self...Thank you so much and if you can add any thing else that would be great...
To New D1 blower alignment Problem
