C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
34 mpg!?!?
Old Apr 18, 2011 | 06:14 PM
danielzo6's Avatar
danielzo6
Default 34 mpg!?!?
I recently supercharged my car and rolled off the dyno last Tuesday. The car is bone stock other than the ECS system with the Paxton charger and a Speed Density tune that was sent by ECS and tweeked by G.R.E.A.D tuning out of suthern Indiana. I was very happy with the results even with the 110,000 miles on the car. I set out for my 3.5 to 4 hour trip to Pidgeon Forge TN for the Rod Run car show last Friday and as I was leaving I filled up with gas and reset my fuel milage on the display. I was so happy when I arrived in TN with the 34 mpg. (and fyi, I am 22 years old and yes I wanted to hear the bov several times with a few 6k rpm pulls) I was happy and yet skeptical so I reset it on my way back, taking it easy at first, I went almost 100 miles and was show 37.5 mpg until I ran into a Maserati on the interstate. I was still able to arrive back home with the 34.x mpg on the dash! I didn't get the pen and paper out to verify it this time but on numerous times before the car has been spot on, within 1 or 2 mpg!
Old Apr 18, 2011 | 07:25 PM
Motorhead-47's Avatar
Motorhead-47
The larger fuel injectors that came with the supercharger are throwing off our fuel consumption calculations. Get out the pencil and paper
Old Apr 18, 2011 | 07:56 PM
danielzo6's Avatar
danielzo6
Ok Thanks! I meant to put this in the form of a question but I see I didn't lol. I will do that and see what the true numbers are because I thought this was crazy high numbers.
Old Apr 18, 2011 | 08:34 PM
StevieK's Avatar
StevieK
You can't rely on the DIC after supercharging. Use the tried and true pen & paper. I had a difference of 5 mpg between actual calculations and the DIC.
Old Apr 19, 2011 | 12:54 AM
mdaniel's Avatar
mdaniel
Banned Scam/Spammer
The only way to know your fuel economy is to divide the # of miles on the tank by the # of gallons. You're not getting anywhere near 37 MPG.
Old Apr 19, 2011 | 01:31 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
injectors over 63.5 pounds will cause the DIC to be off, if below, it will be spot on if the tune is right.
09 and up c6's will be spot on up to 127lbs.
-Carl
Old Apr 19, 2011 | 02:16 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
-Carl
and.... Injectors up to 52 #, for 2006 & 2007 E38 ECMS will read spot of if they don't have a scaled tune from Edelbrock.
2008+ goes to 63.5 #
2009+ go to 127 #
Elmer
Old Apr 19, 2011 | 03:15 PM
LS1LT1's Avatar
LS1LT1
On a recent 110 mile highway ride to Atlantic City in a Cartek Pro Charged/blower cammed C6 Z06 (not my car) I saw over 30mpg at 70+mph on the DIC but I too assume that it might not have been entirely accurate.
Old Apr 19, 2011 | 04:24 PM
Streetfast's Avatar
Streetfast
Have to check it the old fashion way.
Old Apr 19, 2011 | 04:27 PM
eboggs_jkvl
Moderator emeritus
I'm running 27-28 on the highway at 75. High teens in the city. So I'd guess a 22-23 average.
Elmer
Old Apr 19, 2011 | 06:08 PM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
It's amazing how efficient these cars really are. I get 17mpg traveling 75-80mph on the highway. On the gas around town is a whole different story.
Old Apr 19, 2011 | 06:22 PM
old motorhead's Avatar
old motorhead
17? Ha! Don't you have two LS somethings stuffed under that hood?
Old Apr 19, 2011 | 10:58 PM
robertaj's Avatar
robertaj
17 on a supercharged car isnt to bad....
I used to average about 21 (mixed traffic, back roads and some highway)
not a LOT more happy pedal and down to 17 :P but with 600rwhp
Old Apr 22, 2011 | 06:03 PM
BluV's Avatar
BluV
Before S/C - 32MPG and spot on (I have pictures of it too.)
After S/C - the DIC reads 3MPG higher than pencil and paper shows it to be (well, actually "calc.exe").
Old Apr 22, 2011 | 08:52 PM
carlrx7's Avatar
carlrx7
im 17 city 22 hwy with e85 previously with 92 it was 22/27
Old Apr 23, 2011 | 08:31 PM
3 Z06ZR1's Avatar
3 Z06ZR1
-Carl
nope even with 60's the DIC is 17 percent over
Old Apr 23, 2011 | 09:13 PM
carlrx7's Avatar
carlrx7
because the 60#'s are really 72# injectors.
Old Apr 24, 2011 | 09:47 AM
eboggs_jkvl
Moderator emeritus
Out of curiosity...
Are you using the E-Force tune or a local tune made from the base tune and adjusted for the SC?
Elmer
To 34 mpg!?!?
