C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
E Force - Florida
Old Apr 24, 2011 | 04:31 PM
Testshot2005's Avatar
Testshot2005
Default E Force - Florida
Are there any good shops in the central Florida area that install the E Force superchargers ?
Old Apr 24, 2011 | 08:58 PM
drich2905's Avatar
drich2905
fill in your profile so we know where you live.
It helps to know the details when trying to give folks advice
Old Apr 25, 2011 | 06:12 AM
Testshot2005
Default Thanks & Completed
Complete
Old Apr 25, 2011 | 10:15 AM
davidtcpa's Avatar
davidtcpa
Go Canes!
St. Jude Donor '11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21
OP was pretty clear. Central Florida (usually means Orlando).
I know of 2 good ones in So Fla, although I am yet to do mine! You also may want to contact Motorhead-47, he is in the Panhandle, though.
Old Apr 25, 2011 | 12:06 PM
drich2905's Avatar
drich2905
I agree about contacting Motorhead-47.
PM him and he can give you good advice as he is very knowledgeable about the e-force
good luck on your search. Love my e-force
Old Apr 25, 2011 | 12:44 PM
Motorhead-47's Avatar
Motorhead-47
You are more than welcome to PM me for advice as suggested above but I highly recommend you search out a local “brick and mortar” well established local shop with a solid reputation for Corvette work. You don’t want some shop who has never done this install before using your car as their guinea pig to learn on. It is not a complex install but has to be done right. IF you do not find a suitable local shop I can do the job. I am a skilled experienced hobbyist...not a mechanic by trade. I would need the car over a 3 day weekend to knock it out and you and I are 5hrs/350 miles apart. Local would be a better option IMHO.
Old Apr 25, 2011 | 03:36 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Assistant wrench on stand by if needed.
Old Apr 25, 2011 | 07:48 PM
StevieK's Avatar
StevieK
I'm sending you a PM as I'm not sure the shop is a Forum vendor.
Old Apr 25, 2011 | 09:44 PM
TurboLX's Avatar
TurboLX
Next Level Performance should be able to handle this without any trouble. I've worked with Geoff several times before I know he's plenty competent with both the installation and tuning aspects.
To E Force - Florida
