Fans Wont turn On
Fans Wont turn On
Hey guys, I am having an issue with my cooling fans. This is the 2nd time since Supercharging my car that this has happened. I was driving home last night and noticed my coolant temps in the 205-210 range which I knew was not normal with an outside temp of 56 degrees. I suspected my cooling fans were not working. I know my fans are set to come on when the coolant reaches 196 degrees. Since it was so cool out I was able to make it home with no issues. The car ran around 183 degrees once I was on the highway. But my check engine light also came on. I had a problem with my fans last year because of the fan relay melting. Since then the fan wires have been hard wired and I was told I wouldn't have this problem again. Well lo and behold I have the problem again. I am trying to figure out what would have triggered the check engine light. I thought it may have been a blown fuse for the fans but when I got home I checked the fuse and it looked fine. I don't recall the check engine light coming on the last time I had the issue with the melted wires and I can't really see the area where the wires are so I can not confirm that the issue is the wires. Does anyone have any idea as to what might be causing the check engine light? I don't have a tool to pull the codes so I am going kind of blind here. Just hoping someone else may have had a similar issue and has some knowledge of what might be the cause.
I would check the connector for overheating the terminals. If the temp got too hot the check engine light would come on. Most of the connector issues are due to the aftermarket tune, The fan duty cycle.
listen carefully to your fan when you start your engine if it work so nothing wrong with your fan if not just check your fan relay again and your wires and try to connect them directly ,, and the check engine light should appear when the coolant temp gets high don't worry about it ,,, it hapen with me before .
Theres two different connectors on the fans that typically fail. I'm assuming you only hard wired the main one (90% of cases) so you may want to check the other. It's connected to the actual fan motor.
If that's not burnt, your tuner could have turned your fans up too high (100%) and burned the motor out?
The water/anti-freeze wouldn't circulate (fans would be doing no good) and it would overheat harshly if the thermostat failed.
It is likely the connector. Some info here: http://forums.corvetteforum.com/c6-t...d-working.html
This is what mine looked like:
Two years later the positive connection became intermittent as well as the PWM controller burning up.
