We installed my new Dewitt radiator and I do not see a big difference in the temps I still see 212 and it runs down the highway at 185 to 190. Was just wondering what kind of differnece you guys were getting. This car has headers e force cam corsas etc.
"I see 212"...I'm assuming that is in town in traffic?
And if the fan speeds weren't adjusted to take advantage of the thicker core's cooling capability he won't see much if any improvement in town. OP...for a reference point...it was 86 here on Friday and I saw between 192-199 all afternoon running around town...nothing higher.
Exactly what I said...if his tuner didn't ramp the fan percentage numbers up in the tune then he's not going to see much of an improvement at low speeds. Although the OP has not replied back to confirm, I believe the 212 number he mentioned is in traffic/around town slow speed driving numbers. To take advantage of the larger radiator core in the Dewitts, you need to move air cross it. If you aren't moving air, you aren't cooling the car. If his goal is lower coolant temps at low speeds, he needs to move more air.
Stock fan profile
Fan profile used by a well-known tuner
Fan profile I use..similiar mods to the OP's car
If his fan profile looks anything like the first screen capture then it's pretty easy to see how he could see 212.
I'm pretty sure that my tuner has done this and "I" am not seeing much improvement also.
I myself would not waste the money unless you are going with a dual spal setup. IMHO.
I am not sure I follow you. Are you saying "not waste the money" on adjusting the fan speeds? He's already purchased the radiator and the tuning tweak takes maybe 5 minutes and to be blunt.... "it works"! I'd be surprised if his tuner would even charge for the change.
Moving to a dual SPAL fan setup is taking it to another level. They move a ton of air but the dual SPAL fan setup sold by Dewitts requires a separate fan controller and wiring harness to support the additional power requirements of two fans. I suspect they also make a lot of noise. That's fine if you need the cooling but I think it's toward the extreme.
Actually we are changing that. We've been wiring the dual fans together and supplying them with a full load plug connection that you can splice directly in the factory wiring. We've made several of these and they seem to be working just fine.
As far as the OP not running any cooler I think it was correctly stated that the factory radiator was not maxed out. The new radiator is basically being told to perform the same based on the fan settings and the existing stat.
I'm running the Dewitt with FI and never see more than 195 degs even idiling in traffic, AC on and ambient temps over 90 degs! That was IMPOSSIBLE to do with the stock rad without FI and maxing out the fans.....
I believe Motherhead has explained your problem and if not the fan settings then something else is wrong. Cruising temps I'm at 180 to 185 regardless of ambient temps even when putting my foot into the charger....
Tom, are the fans still controlled by the computer then? Just like factory?
Good Stuff ......Thanks guys we have turned up the fans and I NEVER see any temps I worry about. Also the recovery is lots faster (cooling off after moving) I am happy with the fans and was needing a fan profile. Thanks again motothead 47 you can't beat old Air Force hands Hey guys also what additives do you suggest and what results have you seen from them. I'm running water and fresh antifreeze at this point. BTW I still love this thing after 1500 miles are so with no problems. I would take this car anywhere and I do.
-fate-
You'll hear people tell you that straight distilled water with "Water Wetter" provides the best cooling..zero antifreeze. I can't confirm this though and you'd still have to account for winter temps if you went that route. It would be easy enough to experiment with. Distilled water from the grocery store and "Autozone" has Water Wetter on the shelf. I run the distilled water/Water Wetter combo in the supercharger cooling loop.
Glad to have been of some assistance.
Does water wetter provide enough lubrication for the cooling system? I've heard of some guys running straight water and end up with rust buildup in there block & W/P. How true is this, I don't know. Just something I've heard.
I was about to reply with "dunno" but quickly found this on their web site...
"Red Line WaterWetter® is designed to provide
improved metal wetting and excellent corrosion inhibition
when added to plain water or a glycol coolant."
