C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
headers sizing warhawk F1R
Old May 6, 2011 | 08:53 PM
sultan hamdi's Avatar
sultan hamdi
Default headers sizing warhawk F1R
Hi jents
A frined has a C6 Z06 warhawk 500CI block F1R 20PSI what sisze of headers you u recomend him to use ?
thanks
Old May 6, 2011 | 09:29 PM
hucktyson's Avatar
hucktyson
i would have to say 2.125 primarys
Old May 7, 2011 | 06:24 AM
Mr.Big's Avatar
Mr.Big
Kooks 2inch primaries. I run this header on mine fits perfect, as there is not much room for 2inch...
Old May 7, 2011 | 10:56 AM
TrenAman's Avatar
TrenAman
1 3\4 SW's with 2.5 inch collectors w\cats...
Old May 8, 2011 | 10:46 AM
venomws7's Avatar
venomws7
You forgot about the 200shot !!
Kooks or ARH 2inch would be my choice
Old May 8, 2011 | 02:22 PM
Rob@ChampionMotors's Avatar
0Rob@ChampionMotors
Former Vendor
We agree.
Old May 8, 2011 | 02:44 PM
aTX427's Avatar
aTX427
St. Jude Donor '09-'10
I doubt you are going to see 20psi with an F1R on 500ci. An F1r is not enough to feed 6L let alone 8.2. I would highly recommend you drop a line into Dallas Performance about their F2 system. Regarding headers, I would ask that question to the tech's at KOOKS or American Headers. With high boost and 500ci, you are probably going to need more like 2-1/8" primary custom headers with that kind of power.
Old May 8, 2011 | 08:23 PM
Jeremy@HOB's Avatar
0Jeremy@HOB
Former Vendor
Minimum of a 2" collector with a 500ci motor.
Old May 8, 2011 | 11:21 PM
Mr.Big's Avatar
Mr.Big
I know J meant "primary" not collector...
Old May 8, 2011 | 11:32 PM
Jeremy@HOB's Avatar
0Jeremy@HOB
Former Vendor
Good lord. My lack of sleep over the last three days is starting to show. Yes I meant primary.
Old May 9, 2011 | 08:15 AM
venomws7's Avatar
venomws7
When I 1st heard about this setup I said the same thing but I dynoed the car myself 19psi all the way to 6300rpm the car made 851rwhp @4900rpm and then the power falls like a rock @6400rpm the car made 550rwhp the car made 1080rwhp with 200shot which very very low for the setup.
I already talked to Taylor about the F2 System I also told the owner that F1R is extremly small for those 500ci and can't feed it but he wouldnt listen...
Also the owner is not sure about the CI of the engine last week he told me its 481ci .
He's also running the car with on the stock MAF.
here is the dyno graph I like the mid range
Old May 9, 2011 | 08:56 AM
Mr.Big's Avatar
Mr.Big
Need to see boost log...
Old May 9, 2011 | 09:08 AM
venomws7's Avatar
venomws7
I'll try to get it from the tuner..
To headers sizing warhawk F1R
