*****upp twin turbo- new upgrades, new results******
Former Vendor
We have now fully completed the external wastegate upgrade and are successfully running it on two C6's. C5's will be comming soon. For higher boost applications (10+psi) this seems to be a bit more stable to control, and much easier to setup as adjusting the wastegates to match on the internal setup can be somewhat of a hassle.
408 stroker, Spin's cam, 14psi on E85, 818/859. The only reason we stopped is the car was having a bit too much crank case pressure, and we were using a budget boost controler that couldn't opperate both valves on the wastegates.
Enjoy.....
Enjoy.....
That is solid.
600tq by 3500rpm is nice.
Very good results.
The wastegates vent thru the plastic under carriage?
That might make me a bit uncomfortable.
I'd probably extend them a bit further to gain some clearance, but I am guessing you haven't had any issues with anything melting.
Either way, nice job!
edit-I can see it is only recessed on the passenger side.
Very good results.
Actually it's a 402 Ls2 Aluminum block.. Motor has 11 to 1 compression.
Drove the car today... Very quick and sounds wonderful.. UPP has themselves a very nice kit.
Clint
Clint
Former Vendor
That is solid.
Very good results.
Very good results.
CK
Former Vendor
Could always make those clearance holes bigger, too, if it became a problem.
Like I said, very nice kit and results!
Any potential pricing on something like this?
Former Vendor
The external setup is going to be +$300 over the base pricing, though we might just make it a perminate change.
No they're not BB, they're journal bearing, and the turbos are capable of supporting upto 1100hp. Bone stock LS2's with meth and a very mild tune on 8psi we're seeing 600+.
-CK
-CK
-CK
-CK
The external setup is going to be +$300 over the base pricing, though we might just make it a permanent change.
-CK
-CK
Externals are just a better solution, unless someone is going to run a very mild boost setup.
My guess is most people considering this kit would like room to grow, and the external gates give that option.
Former Vendor
