C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Gauges
Old May 16, 2011 | 06:21 PM
phil hunter's Avatar
phil hunter
Default Gauges
I'm having an A & A supercharger kit installed soon on my 2001 LS1. I plan on running boost and fuel pressure gauges, but am wondering if an A/F ratio gauge is worth having. Looking at the Autometer gauges, they don't provide a lot of info, so I'm not sure there is much benefit. That said, they don't cost a lot either. The motor will be professionally tuned by Cunningham Motor Sports.
Phil
Old May 16, 2011 | 06:24 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
Phil
Personally, I would skip the A/F gauge and only run the fuel and boost pressure.
Old May 16, 2011 | 11:12 PM
j_digi454's Avatar
j_digi454
I have those gauges on the A pillar for my E-Force.
Old May 17, 2011 | 09:30 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
me three...
A/F is a light show. Vac/boost & Fuel pressure are your friends.
Elmer
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Really? Assuming A/F gauge means wideband I think that is the single most important gauge to have. If OP is talking about the ~50 Autometer AF gauges that tap into the narrow band then I would agree.
Old May 17, 2011 | 09:32 AM
eboggs_jkvl
Moderator emeritus
Most A/Fs read the stock O2s. Even a wideband would be difficult to monitor while driving. A wideband that can store would be good for tuning.
Elmer
Old May 17, 2011 | 09:40 AM
5 Liter Eater
St. Jude Donor '11
A wide band is no more difficult to monitor than a fuel pressure gauge or boost gauge.
An Innovate MTX-L or AEM UEGO is ~$190. Money well spent IMO even if you're not going to pipe it into tuning software.
Old May 17, 2011 | 09:42 AM
eboggs_jkvl
Moderator emeritus
I would not be opposed to a digital gauge. The green and red light show that most use for display is useless. Another point, you would need 2 of them to see both sides of the engine.
Old May 17, 2011 | 09:46 AM
5 Liter Eater
St. Jude Donor '11
All the WB's I know of are digital as well as sweep. No one uses two. You put it on the drivers side bank where lucky #7 is. If you had an injector failure on the passenger side you would not know it but IMO it's still better than a FPG. But I have both and more.
To Gauges
