ok I am recently in need of a motor for my car. This 376 looks pretty decent for a complete boost ready motor. stab it with intake and oil pan and roll on. But befor I pull the trigger do yall know if there is any builders that can build anything better and as complete as this one for this price? around $5500. Thanks guys
I wondered how the powdered metal connecting rods in that engine would hold up. Sounds like TrenA has been beating the hell out of it. Must be good stuff
I am def pushing the envelope lol. Someone has to be the guinea pig! so far engine is going strong!! I will let you know if anything ever happens, if it does.. cnc time on the heads and will bore\stroke the LSX block!! win\win IMO..
hows that lsx376 holding thinkng about one thanks
QUOTE=TrenAman;1577791212]Solid engine.. I have it.. putting down 888\827 through an auto.. $5500 minus what you sell your pull out engine for.. pm if you want more info..
He sold the car shortly after completion to a guy in the pacific NW...also should make note that on another dyno besides where he had it built, it put down a hair over 700 RWHP. Not knocking or blaming anyone, but almost a 200 HP difference is a lot when comparing the integrity and longevity of a motor.........
Originally Posted by venomws7
Is this 376ci LSX Block?
Yes. It is an iron LSX block. The LSX 376 has powdered metal rods, forged pistons, and a lower compression ratio (around 9.0:1 I believe) than the LS3 counterpart.
Thanks for the help im in between a build 402 ls 2 or this lsx 376 for a fi build for about 800 rwhp is my goal
I would build a motor....the LSx376 is a good option if you need a motor NOW, but it is far from a perfect motor for boost. The powdered metal rods and weak rod bolts are a limiting factor, IMO.
I would rather spend my $5k on parts I picked out.
