My 91mm C6 Build thread!
Also you should really invest in a good back purging setup when building headers like you did, it will greatly help with your weld quality. Although it looks like you may have been using the wrong type of filler metal (ER70 as well?). Or just was clean, too much heat, or many other possible causes of that result.
I hate to see you put this much time and money into something and then start chasing cracks every week.
Cool project and thanks for sharing the pictures! Love the JSB valve covers and intake!
And like i stated before i am not using a footpedal control for my tig so the welds arent gonna look as nice esp. Since this is my first time tig welding..and i thankyou for giving some insight and if theres any.tips u can give a junior welder/fabricator i appreciate it
First let me say again that I understand the time it takes to tackle something like this and I am in no way trying to derail that. In fact I think you did a nice job on the layout and the only real part to be addressed is just in the weld quality. So props to you for the hard work!
Back purge is mandatory IMO on a turbo hot side. It will also help you with heat control as the gas flowing on the inside of the tubing can help to cool the part down. If you were using the correct filler material as mentioned, you need to cut your heat in half at least. Something like that only needs about 45 amps for full pen.
Back purging will also help when you are trying to fill a gap. That is when it becomes more challenging. Learning how to weld properly a gap is most difficult for people. Fitment is of the upmost priority. I have a lot of local customers that fabricate tubing or other parts and want me to weld it up. I have no problem doing that for people but usually the fitment is not up to par and will make the weld look inconsistant.
When I do tubing work I don't start welding until there are virtually zero gaps. Meaning that if you can slip a piece of paper between the joints that is not prep'd properly IMO.
This becomes very important especially when building turbo parts because even if you have a real turbo support like you do (very important) your physical part will actually have stress and pressure built into it. For instance when welding up a turbo header, if you have small gaps in the tubing, as it cools it actully pulls the material together. If there is no gap to start, this is minimized and can be almost eliminated by process of welding order.
This picture shows a welded X joint and two normal parts ready for welding after another fitment check, notice zero gaps:
And wut are u using to make ur cuts, cause i find it extremely difficult to get them perfect using a chop saw or an angle grinder, i was thinking maybe a vertical band saw. ..
If you were only using 40 amps then possibly you just had dirty parts or bad gas coverge? Heat soaking the piping won't cause the welds to come out contminated and black like I saw.
Ohh well, keep the pictures coming, when are you guys expecting to have it finished?
I use a bandsaw as a rough cut and a beltsander to finish to fit up like Taylor was mentioning. I aim for zero gap, certainly no more of a gap than the filler size I use.
All the money you are spending on the car, spend a $150 and pick up a foot or hand control! Try Welding Direct for great prices on TIG consumables and electronics.
Taylor,
Do you use 308L for 304 stainless welding?
What size filler do you usewith a ~zero gap fitup? Do you use a dip-pause-dip sort of welding procedure or do you go for more of a fusion welding approach with the occasional filler dip when necessary or if the metal gets too hot?
Do you use any heat sink clamps (aluminum, copper, etc) on either side of the weld?
Do you use pulsing?
How fast do you think your torch travel rate generally is?
Thanks!
Andrew
Btw what kinda belt sander are you using because i would.think that the stainless would tear the belt up rather quik
Do you use pulsing?
Thanks!
Andrew
I use 308l on 304SS and 321l on 316SS. I always use filler and usually end up liking something a little thicker than half my base metal. For .065" tubing I like .045" filler. Mainly just want to look inside the tubing and see full pen and the exterior of the weld should look slightly convex. Concave weld means too little filler and you now have a weaker than surrounding base metal joint (also the case with fusion welding). Under no circumstances should you use a fusion welding technique on aluminum IMO.
I have a Dynasty 200DX with the pulser but I've only really found it to help make a nice visual weld with a fusion weld. When I am welding piping and such I just carry a constant amperage (amperage should decrease as base metal heats up) and dip filler to give a beaded appearance. If you feed filler in a fluid motion it produces a less common appearance but is just as strong and looks very neat. When I use to do production headers and such I would use this method just from a speed standpoint.
I don't use any sort of heat sink on the other side of the part but I do generally clamp the part to my welding table which is a 7/8" thick aluminum slab. It does a good job of pulling heat out of a flange or something like this and keeping it flat. It also makes a huge difference on fitup and physical welding order according to primaries and other factors.
I like to use less amperage and a slower torch rate on stainless and titanium. This allows the material that has just been welded to cool enough while still showering the area with a gas lense. Trailing cups are cool but very impractical on most welding applications. If you move fast with a higher heat you will always end up with a contaminated weld unless it is being done in a gas chamber. I've had plenty of people argue with me on some of these ideas but this is what I have found to work for me!
Hope that helps.
what type of tungsten and gas mix are u using..
Hope that helps.
This is what I hoped to see, a bit of insight from someone with a LOT of helmet hours and some natural talent. Thanks for the advice!
How would your approach change if you were welding mild steel instead?
Lastly have you tried the pyrex style transparent cups? Are they worth getting?
Thanks!
Andrew
