C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Low Fuel Pressure?
Old Jun 17, 2011 | 11:19 AM
OliverM5's Avatar
OliverM5
Active Streak: 90 Days
Default Low Fuel Pressure?
My fuel pressure has decreased since I first got my car. It used to sit at about 58-60 PSI, now at about 50-52 PSI. I have a A&A vortech supercharger kit and fuel pressure gauge. A few questions:
1) Can the fuel pressure gauge be incorrect?
2) Has anyone seen a reduction in fuel pressue like this and what may be the cause?
3) If the fuel pressure is really at 52 PSI, will it hurt the car to drive it?
Old Jun 17, 2011 | 11:44 AM
Robls6's Avatar
Robls6
GM sets the fuel pressure at 59psi I believe. If you really do have 52psi I would have to think that the pump is going bad.
Old Jun 17, 2011 | 11:47 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
go rent a good mech gauge from the auto parts store, you sender might be wrong.
Old Jun 17, 2011 | 02:49 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
This
Old Jun 17, 2011 | 03:26 PM
jxhunte's Avatar
jxhunte
You need to validate and verify the accuracy of your current meter by comparing its reading with that of another meter (preferably a calibrated mechanical meter known to give accurate readings). If you are using a BAP, you may be witnesing the slow demise of your OEM Fuel Pump.
Old Jun 17, 2011 | 03:35 PM
Streetfast's Avatar
Streetfast
I had my gauge go out on my C 5. Now on this set up it is starting to show 55-57. I'm going to check the gauge. Both times, autometer gauge.
Old Jun 17, 2011 | 05:06 PM
Steve@AandACorvette's Avatar
0Steve@AandACorvette
Former Vendor
From: Oxnard SoCal www.aacorvette.com www.superchargersuperstore.com
If you want to swing by the shop, we'll take a look.
Old Jun 17, 2011 | 05:14 PM
turbotuner20v's Avatar
turbotuner20v
would low fuel pressure show on a wideband as running lean?
Old Jun 18, 2011 | 01:21 AM
OliverM5's Avatar
OliverM5
I really need to get out there ! Been meaning to come down for a while now....
Old Oct 11, 2017 | 07:20 PM
Tommy1995's Avatar
Tommy1995
Mine is doing the same thing. I have upgraded the fuel pump to a lingenfelter high flow pump. I put a ECS stage 1fuel system in. Has double nozzle meth injection. Boost a pump. Still dropping to 51 psi. Could it be caused by stock rails? C6 manual 08. Checked wirhcother gauges and still says 51. Not running lean up top though
Old Oct 11, 2017 | 11:08 PM
Ant-Man's Avatar
Ant-Man
Holy 2011 thread batman.
Could be your fuel filter. rails would not cause it to drop.
Old Oct 12, 2017 | 12:28 AM
Tommy1995's Avatar
Tommy1995
Don't think so. Fuel filters are in the tank on the C6. They get changed when the pumps do and I have new ones on the driver and pass side.
To Low Fuel Pressure?
