I'm running two Maggie TVS2300's. One on my daily driver GMC half ton and one on my LS3 vette. IAT's on both run about 10 to 12 degrees over outside air temps as long as the vehicle is moving. When you stop, the IAT's climb a little. This morning, 81 degree temps on the way to work. IAT's were in the low 90's. Blower case temp was 121 when I pulled up to my office.
I do have a meth kit on my truck. It has a built engine that sees 12psi on occasion. The meth does little for IAT's, but does give an octane boost that safens the setup. No way will I ever hack into my A/C system to add that killer chiller rig. The only time high IAT's have ever caused a loss of performance was at the track. Idling in line, long burnout, etc. Still ran over 131 in the quarter on a hot day. It did pull a few degrees of timing, but didn't pull any of my fun
You can drive yourself nuts over the IAT's or you can enjoy your car. EVERY time I've wanted to go fast, both of my rigs have delivered.
If my IAT's stayed as low as yours I would not be concerned at all. In the winter and spring, I'm higher than you, but within reason. With what I'm seeing now, 140's and up, a fair amount of timing is getting pulled and I'm converned I could hurt something. I think meth would add some safety here.
That said, I totally agree, drive the crap out of it and enjoy it. That what we build them for
Regarding the water/methanol corrosion of the rotors -- I contacted Whipple about this issue as to their 2.9 I have on my SHelby and they said it wasn't a problem.
I'll probably end up with this on my Vette, so if anyone has evidence of damage, please speak up!
Does anyone have evidence that water/meth injection (pre-rotors) for the E-Force has a positive impact on IAT's. I remember reading a post on an earlier thread that suggested water/Meth injection for the E-Force would be like spitting on a Forest Fire. I do not remember seeing data to support this claim one way or another. I would hate to add this system only to find out it is worthless at lowering E-Force IAT's.
Well it doesn't have a negative affect on the IAT's. It is well documented on the Terminator forums that meth pre blower won't lower IAT's by more than a few degrees. But it does allow extra timing from the added octane. Post blower still hasn't caught on for them, not sure what problems they were having but it is obviously not easy to do.
Their Killer chiller device works well for them. The killer chiller company worked with the GTO community to develop a kit for the TVS equiped GTO guys and it worked but not as well as it did for the Terminator folks. Coolant reservoir temps were about -10 below ambient on a 85 degree day a 20-25 degree drop from baseline. Coolant temps in the 50's on +90 degree days in traffic with IAT's at ambient with 17psi, is what the Cobra guys see.
