C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
DIC average MPG vs. actual MPG
Old Jun 29, 2011 | 05:18 PM
StevieK's Avatar
StevieK
Default DIC average MPG vs. actual MPG
Ever since my supercharger install the average MPG shown on the DIC does not match the actual gas mileage when you figure it the old fashioned way, distance divided by gallons used. There is a discrepancy of at least 5 MPG between the two.
Is there anything the tuner can do to compensate for this difference by manipulating the computer?
Old Jun 29, 2011 | 10:16 PM
ABNRGR's Avatar
ABNRGR
Default 25% less
I average 25% less than what the DIC says. I asked this same question right after my A&A SC install. All the feed back was it would be a PITA if it could be done. I just keep in mind to subtract 25% from what I see on the DIC.
Old Jun 29, 2011 | 11:00 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
The computer calculates via injector pulses, your bigger injectors that came with the kit pulse slower to deliver the same fuel as the stockers, this tricks the comp into thinking your using less fuel when in fact you are using more because each pulse delivers a bigger amount of fuel.
Old Jun 29, 2011 | 11:01 PM
DSteck's Avatar
DSteck
Chances are your injector data in the tune is wrong. That's 90% of it.
Old Jun 30, 2011 | 08:30 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
^^ This +10% your IFR value is wrong.
To DIC average MPG vs. actual MPG
