Max Nitrous shots on C6ZO6 fuel system?
07-10-2011, 05:56 PM
How much I can spray approx?
07-10-2011, 06:18 PM
Quote:
Originally Posted by
FreakC6ZO6
i ran 150 with no problem, on a h/c set up with 60 lb injectors
07-11-2011, 09:49 AM
rattt g
Was that a dry shot? OR did you need the bigger injectors due to the h/c setup?
07-11-2011, 09:57 AM
edmundu
it was a wet shot, we made over 600 to the wheels so
we put bigger injectors in
07-13-2011, 11:10 AM
can't go more than 150shot with bigger injectors on stock fuel system?
btw...the engine is built ( lsx block )
07-13-2011, 11:14 AM
We've done 200shot in a couple of cars with 60lbs injectors.
wet shot.
07-14-2011, 01:24 PM
150 shot on stock fuel system
Cam & Bolt ons plus 150 wet shot. Stock injectors, fuel pump and fuel rails, ( Fat tune ) No problems 37,000 miles.
670 rwhp
07-14-2011, 04:54 PM
NOSZ06
670 rwhp
Are you also running the stock spark plugs and timing too? Because if this is the case...Scottie to captain she's about to blow sir.
07-15-2011, 02:14 PM
Thanks Scottie.
Spock the flux capacitor has TR66 plug caps and spark timing is custom correct? Yes captain.
LOL thanks for the humor!
N20 is not just for German aircraft anymore.
07-15-2011, 05:19 PM
What is the hp limit for an E85 car with a stock fuel system except for 83# injectors? Not sure how much if any room for spray is possible with my stock setup. Dry shot that is.
