C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
blue smoke when engine is cold
Old Aug 14, 2011 | 11:05 AM
ultrvet's Avatar
ultrvet
Neat article. When people say they don't build them like they used to they definitely are talking about houses like that one
Old Aug 14, 2011 | 01:03 PM
ISPYPSI's Avatar
ISPYPSI
I would not take the car to a dealership in fear that a tech would do something idiotic, like flash in a stock tune to get rid of the codes. I've heard plenty of horror stories of customers specifically telling the service manager to tell his tech to leave the tune alone and just read the codes, only for the tech to put in a stock tune. Hello catastrophic failure that the dealer will not cover. Find a reputable LSx shop and had the car flat bedded there if you must
Old Aug 20, 2011 | 10:53 AM
ultrvet's Avatar
ultrvet
Turned out to be an injector stuck open
Also turned out to be a ford injector. Lol
Happy ending anyway.
Thanks for the forum members input
Old Aug 20, 2011 | 02:31 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
I remain skeptical, given your initial indications and this bit of information.
I would get this car to a professional tuner before I went very far at all.
You have at least one indication that this engine may not have been put together correctly, and may pay greatlly later.
Old Aug 21, 2011 | 05:02 PM
Cromagnum's Avatar
Cromagnum
Metal expands when its hot, so the fact that you are only having the issue when the engine is cold suggests you have seals about to go (or are gone). I would highly highly highly advise doing a leakdown test as a minimum to check out your cylinders. If you have two side by side acting up -> blown head gasket. If its just one, maybe a stuck or bent valve.
Old Aug 22, 2011 | 09:18 PM
Streetk14's Avatar
Streetk14
Why? Magnuson used those green 42 lb. injectors with those kits, which is a Ford Lightning injector if I'm not mistaken.
And rough running or misfires on cold-start can be caused by a bad injector. I've seen it a bunch of times. Would only show up on cold-start on the ones I've seen and diagnosed first hand. The code he had stored for the cylinder #1 fuel injector backs up this theory even more.
This would also cause the smoking problem on startup. Case closed, I'd say.
Old Aug 23, 2011 | 09:09 AM
ultrvet's Avatar
ultrvet
I have driven the car several times now including running it hard. Absolutely no smoke and it runs perfect.
I think I going along with streetk14 and say that I lucked out and my problem is solved
