C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Supercharger temp question
Old Aug 6, 2011 | 09:12 PM
djwho's Avatar
djwho
Default Supercharger temp question
Hi I have a c6 with a 8 psi supercharger vortech running meth with t160 thermotstat i changed the fan settings and now the car runs at 185 in 80 wearther is this normal or are my fans not turning off??
Old Aug 9, 2011 | 12:37 PM
djwho's Avatar
djwho
Anyone am I jus running the wrong tstat ? Car was running at 175f last nite
Old Aug 9, 2011 | 12:45 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
You dont mention under what conditions. My car runs around 185 also as long as im moving. Higher in stop and go situations.
Old Aug 9, 2011 | 12:47 PM
steve miller's Avatar
steve miller
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I run btween 185-205 max, on the streets here in Florida. 180's on the hwy. Vortech blower, dewitt radiator. You're doin' good. Remove your hood blanket for even lower temps. I lowered my temps 15 degrees by taking mine off. You know when your fans shut off...the noise stope
Old Aug 9, 2011 | 01:11 PM
djwho's Avatar
djwho
I'm jus wondering if it's two low I'm in Canada and here in Vancouver we haven't really had summer i remember last year I was up at 200 I'm jus wondering if I should change my fan settings to run at around 190
Old Aug 9, 2011 | 01:34 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Im not an expert but I dont think your fans should come on before around 195 area. You want the car to reach normal operating temps at least and you dont want to fry the fan harness.
Old Aug 9, 2011 | 03:09 PM
djwho's Avatar
djwho
I don't get how it would jus run at 180 I got a super charger I'm jus wonderin if the fans are allways on that y it's running so cold
Old Aug 9, 2011 | 03:10 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
just listen. The stock fans on these cars are so noisy you cannot miss it.!!!
Old Aug 9, 2011 | 03:25 PM
djwho's Avatar
djwho
I'll check it out when I'm home but I got a blower on it too so it's kinda hard to hear
Old Aug 9, 2011 | 03:27 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I have a blower too. If you cant hear the fans at idle (with radio off of course) , then they are not on.
Old Aug 9, 2011 | 04:56 PM
Motorhead-47's Avatar
Motorhead-47
A couple of comments...there is only ONE fan in the C6 and second comment, if you are running the AC that fan will be on! People often forget that a second table exists tied to AC temps.
What speed the fan runs at what temps is completely tied to how your tuner set it up.
Old Aug 10, 2011 | 04:12 AM
djwho's Avatar
djwho
Yah it does look like the fans are on full time cause the car was at 180f and when I shut it off I could hear something that sounded like a fan after the engine turned off
Old Aug 12, 2011 | 08:22 PM
Oil Rig Pilot's Avatar
Oil Rig Pilot
I'm GLAD this post was created !!!
Here's MY SETUP....
2008 coupe (base), stock - other than the VORTECH V3, SI on my car along with my BB FUSIONS !!
When I GET INTO IT...( taking her up to 170 or so...) my OIL temps rose to 256 degrees. The WATER TEMP was sorta stable around 215 or below...
I have the STOCK therm in it...
the day was about 100 degrees outside - high humidity.
What can I do about these OIL TEMPS ??? any suggestions.
THANKs
Old Aug 12, 2011 | 09:07 PM
djwho's Avatar
djwho
Well you down south I would put 160 thermo and change the fan settings I think 160 is too cold for my car since I'm in canada but ima leav it how it is and see what hapeens
Old Aug 12, 2011 | 09:13 PM
Oil Rig Pilot
Thanks.. I will ask East Coast about this also... I appreciate your input.
- Robert
Old Aug 12, 2011 | 09:16 PM
djwho's Avatar
djwho
Yah let here what they have to say
To Supercharger temp question
