C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Help I've got an Eldebrick
Old Aug 30, 2011 | 10:32 AM
laz51's Avatar
laz51
Default Help I've got an Eldebrick
Hello All,
I've been having a lot of troubles flashing my car with the tune from Edelbrock. It keeps erroring with the following message.
Upload Stock Failed Error 1017
The car has never been tuned and ran perfect until now. I can't start the car because we don't have the computers updated. I've contacted Edelbrock and they had me call SCT. The support guy at SCT says they are having an engineer look into it. This has had me dead in the water since Sunday. I need to get this car running and get back to work.
It's failing during the steps to backup the stock software. So far I've tried flashing while attached to a battery charger. I've tried pulling the radio fuse and the onstar fuse. Nothing seems to help so far.
Have any of you ran into this issue?
Old Aug 30, 2011 | 10:38 AM
laz51's Avatar
laz51
Oh a little more info. The car is a 2007 with an A6 and the Eforce kit is a 1594.
Old Aug 30, 2011 | 10:47 AM
Motorhead-47's Avatar
Motorhead-47
Step #1. Have you downloaded and installed the most current software from the Edelbrock tech site?
http://www.edelbrock.com/automotive_...rs/file2.shtml
Old Aug 30, 2011 | 10:54 AM
laz51's Avatar
laz51
Yep that was the first thing I did. I updated the programmer with the latest firmware and tune before trying the initial flash.
Old Aug 30, 2011 | 10:59 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Honestly and I swear this is true from the depths of my soul, when I read your post, I said, the poor bastard must have an 07! No really! My 07 ECM became a paperweight for the better part of a week with that SAME issue. IT is the SCT handheld causing the issue and the tune. Contact them and Edelbrock and they can get you fixed up.
Look at this and go to post #16 http://www.ls2.com/forums/showthread.php?t=841927
Elmer
Old Aug 30, 2011 | 11:17 AM
laz51's Avatar
laz51
Thanks for the info. Did yours fail in the upload stock phase as well? Do you have any info that I could tell Edelbrock and SCT to shed some light on the issue?
I called Edelbrock today, waited on hold, then got put to someone's voicemail. SCT hasn't updated me yet with any findings. I emailed them the tune I was trying to do.
Elmer
Old Aug 30, 2011 | 11:50 AM
eboggs_jkvl
Moderator emeritus
It failed in the upload and really hosed up the communication with the ECM. Once we managed to reestablish communication, we could do anything we wanted with the ECM. They managed to get a good e-force tune (up to a point) in the car and we got it running rather well. I still have this issue: http://forums.corvetteforum.com/c6-f...ight=dieseling
Elmer
Old Aug 30, 2011 | 01:13 PM
yonson's Avatar
yonson
That is the latest file for the Bosch TMAP, however the file he needs is dependent on what serial number his system has. There is a spot on the Edelbrock website where you enter your serial number in and it will provide the correct file for the system you have. Only difference between the 2 is the TMAP was changed from the Ford to a Bosch unit and has a different transfer function.
http://www.edelbrock.com/automotive_...oft-tech.shtml
Old Aug 30, 2011 | 01:18 PM
laz51's Avatar
laz51
Yep I've gone through that. I entered the serial number for my unit downloaded the file, and installed it in the programmer per the instructions.
I just got off the phone with SCT and they don't know what the issue is.
Old Aug 30, 2011 | 08:29 PM
Motorhead-47
Would you happen to have a friend with either EFILive or HP Tuners?
Old Sep 1, 2011 | 12:00 AM
Six-Gun-Todd's Avatar
Six-Gun-Todd
If you have the ability....take the car to a GM dealer and ask them to flash in the most current OS for your ECM. Sometimes canned tuners have compatibility issues with older OEM programs.
Old Sep 1, 2011 | 03:13 AM
paganharley's Avatar
paganharley
St. Jude Donor '11
I know when I used sct to put my tune in, it did the same thing. Then they told me to unplug the battery for 10 minutes. When I did it took it then.
Hope this might help you.
Old Sep 4, 2011 | 07:19 PM
laz51's Avatar
laz51
Sorry about the delay. It took a while but we got it working. Edelbrock had me try all kinds of things. We flashed to the latest OS. We tried pulling all kinds of fuses. They finally overnighted me a new programmer and that worked. I've got the car running.
Old Sep 4, 2011 | 11:18 PM
magls2's Avatar
magls2
Enjoy your e-force and keep in touch
Old Sep 5, 2011 | 09:44 AM
eboggs_jkvl
Moderator emeritus
We almost got down to hammer smacking the ECM during the loading. Probably wouldn't help much but I would have felt better later.
I'm glad you're up and running. Remember what I said about the proportional tune. Your DIC will have some bad information on mileage and miles remaining in tank unless you get a non-proportional tune into the ECM.
Elmer
Old Sep 5, 2011 | 09:00 PM
laz51's Avatar
laz51
Haha that is some good information to know. I wondered why it said I was making 30 mpg on the way back from installing it. I'm getting ready to have the car tuned because it's running a little lean.
Elmer
To Help I've got an Eldebrick
