C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Ngk tr6
Old Sep 13, 2011 | 08:37 AM
Norman Lane's Avatar
Norman Lane
Default Ngk tr6
Can any of you gents let me know what you have your plugs gapped at on your supercharger vette.
Old Sep 13, 2011 | 09:35 AM
old motorhead's Avatar
old motorhead
.030 - .035. Higher boost closer to .030. Milder boost .035.
Old Sep 13, 2011 | 10:30 AM
Norman Lane
What would you consider 10 to 13 psi
Old Sep 13, 2011 | 11:58 AM
old motorhead
My son's turbocharged GMC and my supercharged vette are at about 8.5psi and .035. My supercharged GMC is at 12psi and the plugs are gapped at .030. I'm not aware of any "rule" to go by. This is just what has worked for me.
Old Sep 13, 2011 | 03:46 PM
3 Z06ZR1's Avatar
3 Z06ZR1
A&A Supercharger's recommends .035 for the tr-6. That requires
closing the NGK factory setting of .039 which is according to NGK is the optimum setting for that
plug. Which is a V-power that has a groove or V cut to increase the size of the spark kernel. Which works best at .039 since the electrodes are parallel at that gap. I run the NGK tr-6 right out of the box.
Just checking to make sure it's still at .039. In order to run the NGK
tr-6 supercharged at .039 You need a better plug wire. Which is just an extenstion of the coil to the plug. I run MSD wires allowing more current allowing more spark at the plug. Allowing you to run the wider gap.
Which is the only way to get a hp gain out of a plug wire.
To Ngk tr6
