It will lower the boost by creating a more efficient air pump... you will gain power, even at the "lower" boost level... so don't be fooled into believing that you will lose power.......
Will adding headers to my supercharged Corvette decrease the boost?
I asked that same question before I added headers to my A&A equipped '07 LS2. I was getting 10 psi with the standard 3.8" pulley and wanted to try and bring it down a couple of pounds. I bought a set of ARH long tubes with hi-flo cats and put it back on the same dyno to retune it for the headers. The same dyno indicated the same 10 psi boost that I had prior to the header installation. I did pick up 18 rwhp with the headers (now 530 rwhp) but was disappointed that the boost numbers didn't drop any. My tuner has reduced the timing (something like 10 degrees at WOT) to prevent detonation on 91 octane gas (no meth). It seems to be working as I have made quite a few 1/4 mile passes and a few standing mile runs and the motor seems to be happy. YMMV
