C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
upgrading slave cylinder
Old Oct 5, 2011 | 06:54 AM
07blkvette's Avatar
07blkvette
Default upgrading slave cylinder
When upgrading clutch should you also upgrade the slave cylinder and if so to what?
Old Oct 5, 2011 | 07:10 AM
Res1cue's Avatar
Res1cue
Stock works fine just upgrade to a new one while you have it apart. I believe SPEC does offer a upgraded slave. What is worth upgrading is the master cylinder to a 7/8 bore Tick unit.
Old Oct 5, 2011 | 09:52 AM
Mr.Big's Avatar
Mr.Big
+1 on the TICK unit
Old Oct 6, 2011 | 05:48 PM
Joey@Tick's Avatar
0Joey@Tick
Former Vendor
Your best bet on hydraulics is to upgrade to our Tick Performance Adjustable Clutch Master Cylinder Kit: http://www.tickperformance.com/tick-...rvette-c6-z06/
...and keep your GM Slave Cylinder fresh: http://www.tickperformance.com/gm-sl...-corvette-z06/
Old Oct 10, 2011 | 03:34 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
It completely depends on the clutch you are choosing. If the clutch calls for an aftermarket, then yes. If not, dont waste your money. We use an upgraded slave and/or master for probably 1 out of 40 clutches.
It is pointless unless it is needed. Not to mention, we have yet to ever use an aftermarket slave/master that doesnt turn the car into a heavy pedal car, with not so enjoyable pedal. But.. I must add, some people really enjoy the way it makes the clutch feel/react.
We do not prefer it.
Old Oct 12, 2011 | 06:51 AM
Res1cue's Avatar
Res1cue
Sounds like someone needs to do some sqwats.
Old Oct 12, 2011 | 12:01 PM
07MontRedcp's Avatar
07MontRedcp
Jeff is the first forum vendor to but his opinion up on the forum, but I have personally talked with another vendor, that will remain nameless, who had the same opinion about the TICK unit having a very heavy clutch pedal.
BJK
Old Oct 14, 2011 | 03:43 AM
CraZee ZO6's Avatar
CraZee ZO6
it is heavy but the tick setup is badass no problems disengaging clutch at high rpms on a slick at the track 7000+rpms
Old Oct 14, 2011 | 09:53 AM
yur2slo's Avatar
yur2slo
The main reason I went with the Tick is unlike the factory unit, the Tick is adjustable (and very easy to adjust as well). I now also have the Tick single stainless steel line going right to the slave instead of the bulky, mid-connection factory unit. Mated to my RPS street twin, it's a tad heavy but I drive my car almost everyday, 60 miles round trip with moderate traffic, and never have an issue. It held up perfectly last Friday at the strip with over 675rwhp and 7K rpm shifts.
Old Dec 22, 2021 | 07:16 PM
Ls1Owe's Avatar
Ls1Owe
5th Gear
the first link is to the master cylinder right ? I have a 2000 frc but the description only said it’s for c6 is this also the one I need ? I’m switching to ls7 clutch also
To upgrading slave cylinder
