Well guys i have a corvette c6 z06 i just bought a procharger and i will be running like 7 psi and i have headers and exhaust so i am looking for what injectors will u all recomend me some guys tell me 80lbs but i need more opinions and if you got a web site where i can buy it if you can do me a favor of post here the web page
A 65# injector will fuel enough for 750hp at 43.5 psi fuel pressure.
I'm assuming you are still running the OE fuel pressure, 58psi. Less the 7psi boost is still an effective fuel pressure of around 50psi. A 65# injector would actually flow around 70#, which is enough fuel for over 800hp.
