C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Ls2 boost e85 which injector?
Old Oct 15, 2011 | 12:11 AM
4SELLL's Avatar
4SELLL
Default Ls2 boost e85 which injector?
Stock ls2 with TTrim and 3.4 pulley on e85 which injector? Using twin walbros...
Old Oct 15, 2011 | 10:03 AM
DSteck's Avatar
DSteck
I'd shoot for Injector Dynamics if you want supeb fuel control and cylinder to cylinder consistency. Just don't be shocked when you see what they cost. There's a reason they cost that though.
PM me if you have any questions. I happen to know a good bit about injectors.
4SELLL's Avatar
4SELLL
I was thinking of those too,,, which would be the size to get?
Old Oct 15, 2011 | 12:57 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
go with the ID1000's, im on e85, make almost 800whp. i think those twin walbro's will be hurting though,, maybe twin aeromotive 340's or add a 40amp BAP..
-Carl
Old Oct 15, 2011 | 05:21 PM
Mr.Big's Avatar
Mr.Big
Depends on your RWHP goal... as mentioned "ID" is the way to go, I run ID2000's and the car carburates flawlessly... Idle, cruise, tip in, WFO, all are spot on. Most important is to make damn sure you use a tuner that has extensive LS2+E85+FI experience... <<<is a MUST...
You are making some very good combination decisions, however as mentioned the tiwn Walbros may not meet your needs if you turn up the wick...
Old Oct 15, 2011 | 05:30 PM
4SELLL's Avatar
4SELLL
I dont really have a HP goal i just want to try to get what i can out of the car and it be middle of the pack on the street and run 10's. I will use AA's Stage 2 blower cam with the TTrim, 7/8s headers, 3" exhaust and the car is going to have a Century 6l80 with a 3200 stall and Z06 3.42 rear/axles so i know that will have a different outcome than if the car had a 6spd. I really dont know what this combo will make but i doubt ill go for any more.
Old Oct 15, 2011 | 11:53 PM
HumanVette's Avatar
HumanVette
I run ID2000 and I like them alot. I have a LS2, YSI, twin deatschwerks fuel pumps and on E85 at 750rwhp I'm at a 50% injector duty cycle. I hate to buy cars parts twice so just went ahead and got the biggest I could for now, the price from ID1000 to ID2000 was not that big of a jump if I remember correctly. Give a few shops a call and see what you can get them for.
Old Oct 16, 2011 | 12:06 AM
4SELLL's Avatar
4SELLL
Thanks for the input guys would be nice to be in upper 600s thru the auto.
Old Oct 16, 2011 | 08:56 AM
DSteck's Avatar
DSteck
The price jump from ID1000s to ID2000s is over 100%. Lol. Retail on ID1000s is $904 and ID2000s are $1919.60.
Old Oct 16, 2011 | 09:17 AM
Unreal's Avatar
Unreal
I would PM DSteck about what he knows about injectors. He helped me out and is a great help to corvette people.
Old Oct 16, 2011 | 02:54 PM
HumanVette's Avatar
HumanVette
lol I'm sure suggested retail price is, I called a few shops when I got mine and NONE of them was near 2K for ID2000. Maybe I just got a good deal because I was getting a few more parts at the same time, but I paid around $1,400 for my new in the box ID2000.
-Edit, I was just going through my old e-mails and I was asking about ID1600 vs ID2000, so their might be a bigger jump from ID1000 to ID2000.
Old Oct 16, 2011 | 03:42 PM
99FRC Newb's Avatar
99FRC Newb
i'm running quad walbro 255's with ID2000 injectors.
Old Oct 16, 2011 | 03:59 PM
4SELLL's Avatar
4SELLL
What's that feeding and is it e85?
Old Oct 16, 2011 | 04:02 PM
lane_change's Avatar
lane_change
Wouldn't your fuel get hot running twin waldos on all the time?
Old Oct 16, 2011 | 04:44 PM
EdwardETraylorIII's Avatar
EdwardETraylorIII
Not at all. Not even with trips. However, quads I do not know...?
Old Oct 16, 2011 | 04:50 PM
DSteck's Avatar
DSteck
Who did you buy from? Shops aren't supposed to sell them below retail.
The 1600 was very close in price point to the 2000 but the 1600 was discontinued due to a flaw in Bosch's injector.
Old Oct 17, 2011 | 02:44 AM
99FRC Newb's Avatar
99FRC Newb
its feeding a twin turbo LS2 in a C5 with E85
no. they are in-tank. they should stay cool, and the second pump shouldn't come on until you are boosting
all 4 are not on at the same time unless i'm full throttle and its 2 pumps in each tank, not all 4 in one tank
To Ls2 boost e85 which injector?
Old Oct 17, 2011 | 12:33 PM
4SELLL's Avatar
4SELLL
Thanks,,, sounds like i need to target injectors and fuel for 1000hp and ill be cool with my setup on E85
Old Jul 20, 2017 | 09:29 AM
Kurt Keister's Avatar
Kurt Keister
3rd Gear
Default What injectors would be best?
Hey, i currently have a 2006 c6 base corvette, amd im looking to put a procharger on it, npw the procharger im looking at says a new feul pump isnt required, but ill need new injectors, which would you recommend, it currently has the stock 33lbs injectors, would you recommend me go to a 46lbs injector or a 57lbs injector? Thank you! Please email me at KurtSK1997@gmail.com
Old Jul 20, 2017 | 12:25 PM
Unreal's Avatar
Unreal
ID1050x, and depending on power level, yes you will need a new pump or pump modifications.
Holy old thread.
