Anyone using the new 6266's with TTiX kit and .82 housings?
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I am going for a full out build with Precision 6266's, 3" downpipes etc etc on a TTiX kit with a 402 cubed motor with my new build. My setup is most likely going to be a hybrid. Precision 6266's with Turbonetics .82 housings instead of standard .64 ones 6266's come with. Not choosing the bigger housings for max dyno numbers but I thought it would be more manageable. My car with my current turbos and smaller housings is almost uncontrollabe the way boost kicks in (auto with no boost by gear stuff) I am hearing from very reliable sources that even with the .82 housings the spooling characteristics will almost be the same! I could only imagine
Anyone has any first hand experience with the new 6266's with .64 or .82 housings on a TTiX kit?
Premium Supporting Vendor
Car I just finished...
382 cube engine, off the shelf cam.
6265 turbos, 0.82 AR Turbine housing, on 17 psi this car has full boost at about 4000 RPM
Standing on it at 3000
By 3250 it has 540 RWT
3500 / 620 RWT
4000 / 700 RWT
Car clearly spinning on the dyno.
You have the benifit of the multiplication of the converter he did not have.
Likely would use a bit larger cam as well.
3500 / 620 RWT
4000 / 700 RWT
There are a bunch of LS2 402 TTi Xs out there. Not exactly a new combo. The difference in your case would be the 3'' pipes & 6266s. I'm looking forward to seeing the results. Who is doing the build? Sounds like a fun winter project.
I'm planning on a six point cage and a Lonny's fuel system over the winter. With that I should be able to max what I have. If that's still not enough I'll explore more options next winter.
The spool on my car is so quick that I don't even need to brake boost. I make peak torque just past 4000rpm. On 11psi I made 770whp and 800 ft-lbs of torque. Granted I have 6265s with 0.82 housings and 3" downpipes on a 427, but not too far off. I couldn't imagine how hard they'd spool with the smaller housings.
That is exactly the kind of setup I look forward to doing.
What size are the injectors?
I think Dave is using ID 1000 injectors. I am going to be going up from FIC 60lb injectors to ID 1000 as well with my new build along with RSI Stage 3 fuel system. Hopefully the end results will be a killer mid 9 second street car trapping 150.XX with A/C and full audio system
I know he has mentioned it previously.
From what he and others have said, those ID injectors seem to be the ticket when it comes to tunability.
I'd spend the extra money, too.
You are building what I think will be one great street car!
That's the goal here, too, full equipment with serious trap speeds!
Best of luck!
That's what I was going for with mine... 150+ trap speeds on pump 93 octane from Costco (don't knock it... because it doesn't knock!) with no meth while keeping AC and heated seats.
Just FYI at this time 62/66's are not available with .82 housings so I went with 62/65's and .82. Pretty expensive stuff for sure but it's going to be worth it in the end
Former Vendor
St. Jude Donor '06 & '12
I was just reading in one of our PRI books, that Precision will be unveiling a new version 64/66 in Orlando in December. Im excited to get my hands on one. Hopefully it will be a nice middle road between the 62/65 and 67/65.
