Blue Devil 900hp YSi
Hey Fellas !
I got a chance to hit the rollers down at Champion Motors today. The clutch is acting up a little but we still managed to get er done !
Details on the build :
A&A YSi Kit
Stock LS7 Head
3.625 stroke x 4.125 bore 397ci
8 Inch Balancer, 2.95 Blower (Flip Drive)
Thanks to Rob, Pete, Fern, Alex, & Kevin at Champion Motors ! Thanks to Arun for sending me the idler I needed to keep consistant belt tension.
A&A YSi Kit
Stock LS7 Head
Power sounds low for that combination. How much boost?
Car we just finnished up made 915rwhp @ 6500 (loaded dyno) on a 3" pulley, 8 rib setup, no flip drive (no belt slip). 9.0 Comp 364ci. This was at 17.8lbs on 93 with Meth.
Id think that engine has quite a bit more on the table.
Hey Fellas !
A&A YSi Kit
Stock LS7 Head
A&A YSi Kit
Stock LS7 Head
That's sick power!!!! 880rwh @ 7000rpms, never seen that, Batman!!!
http://forums.corvetteforum.com/c5-f...ts-are-in.html
It has a 3+ spec in it.
It will never see the dragstrip..
I am confident she will put down 950hp.
I congratulate you on the numbers. We pretty much had the same numbers and, while it ran, it was a blast. I had a Fidanza twin disc in mine and it held pretty well. Mine ultimately blew up again so I envy those with running cars! Enjoy.
Who are you ? IM BAT MAN
