C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
6 Rib Limit
Old Nov 8, 2011 | 01:09 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Default 6 Rib Limit
I make ~14# with the stock ECS 6 rib pulley which is 3.25" without the restrictor. I do need to tighten the belt down good but when I do I avoid belt slip. I'm looking for a little more, say 17#'ish, but I'm not willing to swap everything out to 8 rib or add a flip drive. What do you think my odds are of getting away with a 3.125" Reichard pully? It would be an 8 rib but everything else would be 6.
Old Nov 8, 2011 | 01:18 PM
Flash20's Avatar
Flash20
add some spray
Old Nov 8, 2011 | 01:26 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We have not had any issues with the 3.25" pulley and a six rib as long as the belt is properly adjusted. Including nine second passes etc.
When you have your belt installed and fully tightened, see how much farther the tensioner will open at that point. You may need the next size smaller belt to get the tensioner to fully open when the engine is at rest.
In cooler weather we have repeatedly recorded 18 lbs from that combo on a stock LS2. If your cammed that will drop, but you get the point.
Old Nov 8, 2011 | 01:35 PM
5 Liter Eater
St. Jude Donor '11
Hey Doug,
Yea I'm not seeing problems with 3.25" as long as I don't get lazy with tightening it. I see 14# with your cam when tight. I'm looking for ~17#. Would a 3.125" do that?
Old Nov 8, 2011 | 02:24 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Originally Posted by 5 Liter Eater
Hey Doug,
That would put you right around where your looking to be. 17 warm-18 cold with that.
Old Nov 8, 2011 | 02:27 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Why 17#? Because RACECAR!
You got the new short block in the works?
Old Nov 8, 2011 | 02:50 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Jeeze, Bill...push it to the limit
Old Nov 8, 2011 | 03:19 PM
5 Liter Eater
St. Jude Donor '11
Maybe I'll just knurl the input shaft.
Old Nov 8, 2011 | 03:23 PM
5 Liter Eater
St. Jude Donor '11
Na, but I've been working under the assumption that it could let loose at any time for ~1 year now at 14# so whats a few more pounds?
Hanging out with Mr. Big and User_Name tends to shift your definition of "limit". I was reminded over the weekend that Big was pushing his stock LS2 harder than me for quite some time before he got tired of trying to break it and forged it.
Old Nov 8, 2011 | 03:26 PM
FloydSummerOf68
I'd create a public memorial in your name to honor that feat.
Old Nov 8, 2011 | 03:30 PM
FactoryRaceCar
I tried that for quite a while with my C5. Couldn't do it. Finally end up donating that motor to someone who ran a bunch of 9 seconds passes with it before blowing it up. Some of these motors are factory freaks. Others, not so much!
402 topped with AFR's and 62/65's with .82 housings. I heard someone said those things to me a couple days ago and sure it all sounded good
Old Nov 8, 2011 | 04:00 PM
DOUG @ ECS's Avatar
DOUG @ ECS
We are putting a Novi 2500 on a C6Z today and didnt have the right belt in stock and were talking about doing that. (not literally)
Old Nov 8, 2011 | 07:13 PM
White_Lightning's Avatar
White_Lightning
Time to crank it up Cant have old Charlie murphy out ahead of you
Old Nov 8, 2011 | 07:31 PM
turbotuner20v's Avatar
turbotuner20v
is it the ECS bracket that allows such high boost, or would you have similar luck on a procharger 6 rib? I'm running a 4.75 making 9 psi on a 6 rib and am thinking of adding boost
Old Nov 8, 2011 | 07:35 PM
user_name's Avatar
user_name
Shouldn't have posted this. I'm going to order a nitrous kit now.
IMO you are letting your cheapness get in the way of running fast and RELIABLE. The stock balancer is a piece of ****. I'll bet the stock balancer flexing is the cause of some people throwing belts and slippage. You gotta bite that bullet. While you are in there you may as well do the other 8-rib pulleys.
Damn. Can't believe I actually gave you the advice you need to beat me...
Old Nov 8, 2011 | 07:36 PM
White_Lightning
He knows his truth
Old Nov 8, 2011 | 07:37 PM
inspector12's Avatar
inspector12
Ha ha ha! Come on Bill! What you trying to do, your one of the few that came back not busted, unlike me lol! do you have the inovators west crank overdrive on as well?
To 6 Rib Limit
Old Nov 8, 2011 | 07:42 PM
Rams01's Avatar
Rams01
Get a damn 8 rib.
And while you do that, ill do rods/pistons/nitrous this winter
Old Nov 8, 2011 | 08:24 PM
1SwtRide's Avatar
1SwtRide
Inquiring mind(s) want to know . 2500 in a C6Z, hmmmmm - do tell (after dinner of course..)!
Old Nov 8, 2011 | 08:41 PM
Bobby @ LG Motorsports's Avatar
0Bobby @ LG Motorsports
Former Vendor
Did you guys see Rickys pewter C5 with the D1 last weekend? 736 rwhp on 14 psi, 817 with a 50 shot He pilled it up to 100 shortly after. Its a stock LY6 engine ( low compression LS3) with a cam and D1 with spray
Stock shortblock record?
Its a 6 rib too, but 3.6" upper, stock lower.
