C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
8.5" Innovative Balancer
Old Nov 20, 2011 | 11:33 AM
LB's Avatar
LB
Default 8.5" Innovative Balancer
I believe Arun @ CPP may have done this modification. I wanted to know if an 8.5" Innovative 10Rib Balancer will clear the subframe and Aftermarket Mesier Water Pump Bell.
Old Nov 20, 2011 | 03:04 PM
WHITE_SHARK's Avatar
WHITE_SHARK
Maybe you want to check this first as I have a confirmation from Andy@A&A
that the electric water pump cannot be installed with theire C6 bracket!
on the C5, it can be installed after some modification!
Old Nov 20, 2011 | 04:20 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
Won't fit.
Old Nov 20, 2011 | 04:27 PM
LB's Avatar
LB
Originally Posted by Arun@CCP
Won't fit.
Any idea what modifications would be necessary in order to make it fit ?
Old Nov 20, 2011 | 04:46 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
You'll get more blower rpm by running a smaller blower pulley.
If you want to try the bigger crank pulley, you'll need a new FD, new waterpump, new blower idler pulley's and subframe clearancing.
Old Nov 20, 2011 | 07:20 PM
LB's Avatar
LB
That answers my question ! 8" Balancer it stays
To 8.5" Innovative Balancer
