Anyone use drive shaft shop carbon shaft
#41
I cant say yet as im waiting for my dss axle shafts but I did also do RPS bc3, had rockland standard gear build me a tr6060 and added a eaton lsd diff. Should be on the road in two weeks and we will see how the dss shaft is.
#42
Former Vendor
Thanks for the input everybody! Some have told me that the strongest drive shaft to get would be an aluminum one from the driveshaftshop. But race cars seem to like the carbon fiber piece
I'm in a pickle about which one to get! Also, do any of these upgrades come with warranties?
DSS has an unlimited milage 1 year warranty. Not sure on the Pfadt shaft.
#44
We sell the Pfadt ones as well. They are great pieces. Albeit 1/3 more the cost of the DSS shaft. Also, Pfadt doesn't bond thier own units, they have it done somewhere else.
Either way, we have used both types an both have preformed flawlessly
In a manual transmission vette you need to get a carbon shaft. The car will shift much faster and easier with a lightweight carbon shaft.
We have a 1 year warranty against manufacturers defect on all of our parts. Our Carbon Driveshaft system has an excellent track record in the field and we're very confident that they can handle what ever you can throw at them!
#45
DSteck....do I need the coupler and bearing kit from rpm? I thought these shafts already come with their own version specifically, designed for their shafts
#46
Former Vendor
We have our Carbon Fiber Driveshafts wound and the drive ends bonded by the same Mil Spec composites company. They specialize in lightweight carbon fiber tubes for various uses the US Military might have. They're definitely strong enough to handle what a Corvette can put out.
#47
TJ from RPM has RPM parts in his car? NO WAY!
#48
St. Jude Donor '08-'09
I have the Carbon Fiber shaft, if i had to do it again, id go with the upgraded poly couplers and aluminum shaft, too much of a NVH increase, and i have a slight vibration from 2k-2.5k. i even mic'd the shaft and its less than 3 thousandths runnout from center
Apparently that's not good enough, even though stock is 80 thousandths tolerance., but that's using rubber couplers.
If anyone wants to trade, LMK, straight up, DSS aluminum with poly couplers for mine.
-Carl
-Carl
#49
Former Vendor
-Carl
-Carl
#50
Here's the Pfadt flex discs. No increased NVH for me. I also run the Pfadt engine and trans mounts.
Carl, I have a 3.5" DSS driveshaft just sitting here if you want a cheap one... I have solid aluminum couplers, so you'd still want to buy the poly ones.
2 foot headers? Holy ish!
#51
I too have the Pfadt engine and trans mounts, along with the ECS brace and Pfadt spherical bearings, thing is a vibration nightmare when it comes to standard road noise, but im use to that, the 2500 rpm vibration bothers me.
-Carl
#52
Former Vendor
I'd need a non drilled input/output shaft, will wait till someone wants to trade. ive gotten r2ing the tt down to about 5 hours on jackstands.
-Carl
-Carl
#53
-Carl
#55
All of these questions are serious and not meant to be taken as a smartazz.....
1) Can anyone produce evidence of increased performance from switching to a CF DS ?? ET/MPH ??
2) Who is breaking the factory DS (not couplers) ?? And what rwhp is this becoming the norm ??
3) And it seems prices are all over the board between the several CF manufactures ??...why ?? $899-$2000...??
Shafts
1)PFADT
2)LG
3)Hinson
4)ECS
5)Driveshaft shop (DSS)
6)etc...
Couplers
1)OEM
2)Billet
3)Ti plates/flex disc (PFADT)
4)u-joints
5)a combination of some of these or a complete elimination of these
6)etc...
What are the specs of some of these CF shafts ??
1) weight ??
2) weight with coupler/design ??
3) wall thickness ??
4) O/D ??
5) run-out tolerance ?? V-block ??
6) how tightly do they hold their balance specs
7) etc....
Do some of the coupler designs have benefits as to the type of performance atmosphere the car will see ?? Road race, drag race etc...??
By looking at pictures of some of the drive shafts, it almost looks as if some of them are made by the same manufacture and vendor "A" puts their name on them and sells them as "theirs".?.? Like ACPT..
So if anyone in the "know" can shed some light on this subject, I would appreciate it.
And lastly.....if no one is breaking the $900 CF shaft and its "specs" are very close to the other manufactures specs....then why by the high-dollar unit ??
Thanks.................and FYI, I run a FP, 30 spline,T56 w/BC2....so I'm interested in this topic.
Shafts
1)PFADT
2)LG
3)Hinson
4)ECS
6)etc...
Couplers
1)OEM
2)Billet
4)u-joints
6)etc...
1) weight ??
4) O/D ??
7) etc....
#57
Bump....for some specs and guy can make a decision on/from ??
1) weight ??
4) O/D ??
7) etc....
Thanks...........this is race to build a competent driveline, not a race to see who can spend the most $$
1) weight ??
4) O/D ??
7) etc....
#59
