C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Dyno graph request: E-force versus centri kits
Old Dec 17, 2011 | 09:30 PM
  #61
BADZ's Avatar
BADZ
Just like Andy says, the YSI is out of control and just what I like. -haha.
The t trim (sl1500) is a killer blower and does make great power!!!
Old Dec 18, 2011 | 06:35 PM
  #62
Random84's Avatar
Random84
Originally Posted by Fordracer9
Totally stock 10 GS with A6 and ECS 1500 kit only.
Thanks! Looks like you start making 400+ ft-lbs at 3000 RPM, similar to other centri graphs I've seen.
I found this comparison graph of an E-Force on an otherwise 2010 Grand Sport (did not specify A6 or M6!). Looks
This looks pretty close to the Edelbrock graph of a 554 HP LS3 E-Force found on their website so it appears realistic. I'll take these two "real world" dyno graphs, with the understanding that there may be environmental, dyno, transmission/gearing or other differences that we can't be sure of (given the lack of information on the second graph I pulled from the internet)... of course that's why I posted - but so far these are the closest graphs I've seen.
Combined graphs: note, I rounded all numbers based on how well I could read the graphs above.
* the E-Force makes almost 75 ft-lbs more torque at 3,000 RPM and below; but the ECS unit quickly reaches parity at ~4,000 RPM and makes 40 ft-lbs or more than the E-Force unit at 4,500 and above.
* HP is similar through 4,000 RPM: ECS 1500 makes 25+ HP more at 4,500 RPM and above - with peak HP at 5,500 RPM bringing a 50HP advantage to ECS.
These graphs are not terribly surprising - however it is nice to see a definitive range of where each system is more powerful. I will also admit that the E-Force has an advantage higher into the power-band of the LS3 than I would have expected (~3,500 RPM). However, I think that if one realistically watches the tachometer while driving, very few of us do any performance driving where we do not stay above 3,500 RPM when getting on the car. That range is typically for highway cruising or stop-and-go traffic - where boost is not demanded or required.
If we are realistic and say "where is my engine when I pass someone, or when I get on it from a stop light?" then I think most of us will agree we're going to see 4,500 to 5,000 RPM before shifting, even under the most forgiving of drivers who are not comfortable pushing a 6,500+ RPM redline (what these engines were built for...).
To each their own, of course - but since so many of us want "OEM driveability - but with more power when we need it!" it appears that the centri units match this quite well. So if you want OEM driveability, and you're not stomping on the pedal under 3,000 RPM, why choose a unit who's primary advantage is in this band? As I've asked before, is anyone really passing someone on a two-lane road in sixth gear?
Old Mar 3, 2012 | 07:18 PM
  #63
captainbob's Avatar
captainbob
Originally Posted by Motorhead-47
There is so much misinformation in this thread. #1 is assuming the Edelbrock can only come as 554 or 599hp. Like any other supercharger, there are many ways to build the car. Here are a couple of dynos from an Edelbrock for you.
And a couple of timeslips from a 2011 GrandSport A6 (stock converter and gears) with Edelbrock, headers and LG mild blower cam.
Killer runs.. OMG.. I'm impressed.. After reading all of this thread I was beginning to second guess my Eforce purchase.. Nice numbers.. I'm assuming you have the 600 (1591) kit plus headers, and cam?? How is it for everyday driving?? How much gas mileage did you loose??
Old Mar 3, 2012 | 08:36 PM
  #64
White_Lightning's Avatar
White_Lightning
Dallas performance D1SC kit
Dallas performance Fi Cam.
WCCH heads
alky meth.
LG 1 7/8" super pro's
13# peak, very conservative tune
this was with a 4 3/8" pully on the blower.
if you want to roast your tires off the line, or race from 1500 rpm in a gear.. PD blower..
for power in the rpm range most races are run in ( besides initial launch) Centri or turbos imo.
Old Apr 12, 2012 | 12:29 PM
  #65
Iron Texan's Avatar
Iron Texan
Originally Posted by 5 Liter Eater
I have to agree with Andy regarding the "feel" of the top mounts. The torque is instant and stays there so the feeling is "flat" like he described. I like how the certri continues to keep you pinned in your seat.
This is a good point. In driving both my 04 Cobra and an 03 Lightning, I felt like the cars seemed slower than their numbers would suggest. I drove the Lightning first and assumed that it was a weak running example. With the Cobra the car was obviously fast, but as said above, it felt "flat". And if I am honest, blowing off the tires every time I attempted to accelerate under 40 miles per hour, became a little annoying in day to day traffic.
Also, heat soak was unreal with the Cobra. On a hot Texas day it could feel like I was down 80 horsepower than when the engine had just been started up on a 60 degree day.
I would say my LS3 C6 with headers and a tune is about equal in speed, maybe a little faster, than my Cobra was, but because of the power band building up the way it does, it feels considerably faster when accelerating.
I initially believed I would enjoy roots style blowers more than anything because of the claims that "they are best for the street" and me being annoyed with a naturally aspirated build killing all of my power under 3000 rpm, making be believe that what a car needed to be fun was epic low end torque.
The nice thing with a centri is unlike an NA build you don't lose any power down low, you gain everywhere, but it still builds up its power through the power band like an NA motor, instead of smacking you in the face with a borderline unusable torque curve and "flat" feeling acceleration.
Now all that said I don't have any comparison dyno graphs and as stated my C6 is currently N/A. But I do have the experience of having owned N/A, turbo, and Roots equipped cars, and daily driving them. Maybe it will help someone with their decision.
Old Apr 12, 2012 | 12:50 PM
  #66
3 Z06ZR1's Avatar
3 Z06ZR1
There is no such thing as an "out of the box" A&A or ECS kit...neither comes with a calibration and both require a custom dyno tune for each vehicle. A custom tune always yields better results when done properly...at a price...typically $400-$750 extra.
The Edelbrock published numbers are real numbers easily repeatable on an engine dyno all day long...554 or 599 at the flywheel for the two boxed configurations. If you want/expect something different, buy the tuner kit and choose your injector size, pulley size and then have it professionally dyno tuned.
There certainly is an "out of the box A&A kit"
One was delivered to my door! They are ALL out of the box!
Just mail your ecm to A&A.
They flash it and return it. You have it back before your ready.
Yes you can use a custom tune for best result.
All day easy repeatable results? EFORCE? When there is at least two or more posting
in this thread that thats Questionable at best!
Old Apr 12, 2012 | 03:13 PM
  #67
captainbob's Avatar
captainbob
Wow, I have an eforce and am runing 11.5 consistently not probs.. Out of the box with an ultra safe tune.. The blower fits like a glove, and couldnt be happier. All I had to do is grab some good DR's I'm good to go.. With the AA you will need a good custom tune so plan on spending an extra $500.. I almost went with AA but like the low end torque over the centri.. Purely my preference thats all
Old Jun 1, 2012 | 02:49 PM
  #68
GR8GAME's Avatar
GR8GAME
What kind of power are you making? What other mods exactly?
Old Jun 4, 2012 | 12:29 AM
  #69
3 Z06ZR1's Avatar
3 Z06ZR1
This is a V3si trim on my 2008 Z-06 with it pretty much fully heat soaked.
Even fully heat soaked it had 441rwtq min @2500 so you can see where a stock car
comes up short.
It has a 1500 Paxton now.
Old Jun 4, 2012 | 03:40 AM
  #70
captainbob's Avatar
captainbob
530 rwhp, mods are Eforce 599, and AR headers 1 7/8 cat delete, and some NTO5R Dr's.. Actually ran an 11.3 a couple weeks ago.. I got the slow it down warning for exceeding the 11.5 with no cage.. I wont cage the car so I'm done with adding horsepower.. Low 11's is perfect for this set up, and the car drives so nice on the street still gettting 26 MPG..
Old Jun 4, 2012 | 08:47 AM
  #71
realcanuk's Avatar
realcanuk
St. Jude Donor '13
comes up short.
Since your so busy bashing Eforces and their owners I will have to throw in that those are pathetic results. Here is the sheet from my car. Stock with eforce and alky control. And just to make things more clear... its an LS2, not an Z06 !! 441rwtq doesnt even exist on my car.
Old Jun 4, 2012 | 03:04 PM
  #72
3 Z06ZR1's Avatar
3 Z06ZR1
Yes those were with a V-3si trim! That was running at 230 plus degree's. HEAT SOAKED! I have a 1500 Paxton on it now!
Making more than yours! I have more like 675 to the wheels!
plus
My car is certainly FASTER than yours!
Talking about the little girls on here and there panties in a bunch!
I don't have any problem with the Eforce or the owners. I didn't bash anyone! I just pointed out that 119 mph trap speed is slow for a F/I car then I get smart remarks and bashed back. You can take a long walk off a short pier!
Old Jun 4, 2012 | 03:09 PM
  #73
realcanuk's Avatar
realcanuk
St. Jude Donor '13
plus
A battle of wits with an unarmed man.... I'll pass. Have a good day.
Old Jun 4, 2012 | 03:18 PM
  #74
3 Z06ZR1's Avatar
3 Z06ZR1
Yes, I did feel that way about you! You have a good day also!
Old Jun 4, 2012 | 03:33 PM
  #75
FloydSummerOf68's Avatar
FloydSummerOf68
Ha....that literally made me lol
Old Jun 4, 2012 | 03:53 PM
  #76
backchannel's Avatar
backchannel
[QUOTE=Rock'n Blue 08;1580986169]Yes those were with a V-3si trim! That was running at 230 plus degree's. HEAT SOAKED! I have a 1500 Paxton on it now!
plus
Did I miss - what are your 1/4 results?
