C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Problems installing E force on 2007 Z06
Old Dec 23, 2011 | 03:07 PM
ZR-1 1991's Avatar
ZR-1 1991
Default Problems installing E force on 2007 Z06
As title states , Does anyone know ?
1 How do you install the oil cooler ?
Seems like there is no way in the world to tighten the bolt at rear !
2 Do you have to remove driver side cat ? If so how do you get at front bolt ?
3 How tight does the plug that goes in the frost plug have to be ?
Thanks In Advance
Old Dec 24, 2011 | 09:42 PM
ZR-1 1991's Avatar
ZR-1 1991
Anyboby know ?
Old Dec 25, 2011 | 12:27 PM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
If your talking about item #2, it gets torqued to 44 ft lbs.
Also, If you dont already have them. The installation iunstructions are posted here http://www.edelbrock.com/automotive_...rgers/1573.pdf
Old Dec 25, 2011 | 12:41 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
For those reading this, the Z06 kit is supplied with an oil cooler similar to that used on the new Camaro -
1 - Remove the manifold and cat
2 - install cooler
3 - Re-install Manifold & Cat
The "frost plug" you are referring to - is that the metric threaded plug with copper washer? If so, the torque is not high (under 25 ft lbs)
Hope this helps and merry christmas
Thanks In Advance
ZR-1 1991's Avatar
ZR-1 1991
thank you for posting , I have the instructions , no where is this in the instructions, Here is what it says.
95. Install the supplied threaded fitting into the hole
previously occupied by the freeze plug.
The other 2 bolts hold the cooler to the motor
101. Secure the oil cooler by tightening the bolts that
come with it into the flange on the oil pan, then install the
supplied bolt through the oil cooler assembly and thread it
into the bracket mounted to the oil pan rail.
No torque listed.
Old Dec 25, 2011 | 12:51 PM
erick_e's Avatar
erick_e
1 Engine Oil Cooler Adapter Fastener (Qty: 2)
Tighten 8 N·m (71 lb in)
2 Engine Oil Cooler Adapter Fastener (Qty: 3)
Tighten 35 N·m (26 lb ft )
Old Dec 25, 2011 | 12:52 PM
ZR-1 1991's Avatar
ZR-1 1991
2 - install cooler
Thank You for reply , and MERRY CHRISTMAS to you too,
It's the plug. No 2 in picture . I have a Canadian Z06 , It came with a block heater , in that hole , instead of a frost plug .
I don't want to over tighten it , nor do I want it to leak either
Old Dec 25, 2011 | 12:56 PM
0C_Williams@RPM
Former Vendor
I'll check the exact spec when I get to the shop and post back the correct spec
Old Dec 25, 2011 | 12:58 PM
ZR-1 1991's Avatar
ZR-1 1991
Thank you .THANK YOU
To Problems installing E force on 2007 Z06
