C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Question abaout E FORCE .Shut down .
Old Feb 6, 2012 | 10:50 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
FYI, somewhere in the recesses of my old and rusty brain, I recall that the Z06 does not have the issue as the C6 non Z06. Your reset seemed appropriate to you for the circumstances you had. I did not replace the ECM. I did not have to change the OS, I have smooth idling, good performance (good is a relative word and I am exploring some small HP numbers I have), the ONLY thing wrong with this car is is doesn't like to stop. Sigh...
I still have to do some driving testing today and see if the relearn actually did something for my issue of dieseling. I'm doubting that it solved the problem.
Elmer
Old Feb 6, 2012 | 02:02 PM
eboggs_jkvl
Moderator emeritus
Started the car. Drove about 1 block and shut it off. Dieseled. Started the car and finished driving around the block. Pulled car into garage and shut it down. No dieseling.
As I said, I don't think the CPS Re-Learn is a mandatory function of the install unless you replace the OS or ECM as you did.
Elmer
Old Feb 6, 2012 | 03:14 PM
ZR-1 1991's Avatar
ZR-1 1991
Elmer
Sorry to hear that Elmer , Could you have a bad Crankshaft Sensor ?
Old Feb 6, 2012 | 03:33 PM
eboggs_jkvl
Moderator emeritus
If I had that, I'd think my car would run badly, miss, idle terrible, or something to indicate a bad sensor, not to mention it tossing a DTC complaining about a problem.
So, back to the drawing boards.
Elmer
Old Feb 6, 2012 | 03:45 PM
ZR-1 1991's Avatar
ZR-1 1991
Elmer
It may not set a code. Have you tried hooking up Tech 2 and checking each cylinder ?
Old Feb 6, 2012 | 03:54 PM
eboggs_jkvl
Moderator emeritus
For misfires? I'm not tossing any codes even when at WOT on the dyno.
Old Feb 6, 2012 | 04:24 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I am still betting the exhaust solves the issue !!
Old Feb 6, 2012 | 04:32 PM
ZR-1 1991's Avatar
ZR-1 1991
Misfires may not set a code. The SCT showed nothing .on the Tech2 no code but when you check each cylinder , it showed misfire.
Old Feb 6, 2012 | 05:29 PM
eboggs_jkvl
Moderator emeritus
Well, we'll know very soon. It was due to arrive today at the shop. I just checked UPS, per their records it was delivered at around 11:15 AM today.
Elmer
Old Mar 1, 2012 | 08:04 PM
C6psi's Avatar
C6psi
Hey guys, just to chime in on the 07 C6 Eforce issue...I installed mine about 6 months ago and with the Edel tune had no dieseling! Car performance was great but would die after a bump in the throttle or a push in on the clutch after coming to stop. I contacted Edel and they told me to download the latest tune which I did with no change at all to driveability. Took to a local shop to tune it so we could get it to Idle and bamm.... now it Diesels! Every Fricken Time! Got to be the tune.
Old Mar 1, 2012 | 08:07 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
I agree its in the tune because they don't all do it.
Old Mar 1, 2012 | 08:16 PM
ZR-1 1991's Avatar
ZR-1 1991
Not the tune, it's the crank sensor !
Old Mar 1, 2012 | 08:21 PM
  #33
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Dunno. Mine was doing it but after I put headers and retuned it doesn't any more.
Old Mar 1, 2012 | 08:31 PM
  #34
C6psi's Avatar
C6psi
Exactly, mine was not doing it and the only change was the tune and then Just want it to stop!! Elmer...my sympathy brother... I have followed your saga and check in often to see if you have found the holy grail to resolve this issue for all 07 C6's
Old Mar 1, 2012 | 08:50 PM
  #35
C6psi's Avatar
C6psi
Realcanuk, are you running the 550HP kit or the 599HP kit? What all did you change on the Exaust....sounds like a great reason for some headers!!!
Old Mar 1, 2012 | 09:09 PM
  #36
realcanuk's Avatar
realcanuk
St. Jude Donor '13
599 kit. Added ARH 1 7/8 headers and cats. I believe Elmer added headers and still has the problem which makes me think its the tune, but it really is a mystery.
Old Mar 1, 2012 | 10:26 PM
  #37
C6psi's Avatar
C6psi
I hate it for him...I have given up on projects in less time he has been trying to fix this one. Tough to believe that Edel would let a problem like this go unresolved for this long even if it is isolated!!
