C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Gauges
Old Jan 28, 2012 | 10:36 AM
FireRescue's Avatar
FireRescue
Default Gauges
I will be installing a SC on my 2005 in the near future. I have researched and seen many different options out there to monitor the performance of the car and how the car is running.
I have a two pod pillar gauge pod. Other than the obvious boost gauge. I am looking for the best gauge to install to monitor what the vehicle is doing. I was looking at the fuel pressure or EGT gauge. Any other suggestions, what would be the best and why?
Old Jan 28, 2012 | 12:34 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
Instead of EGT I would recommend an Air Fuel Ratio gauge. I had boost and fuel pressure in mine. On my next build I'm planning on boost and AFR, or maybe a 3 pod with boost, FP, and AFR
Old Jan 28, 2012 | 12:49 PM
Unreal's Avatar
Unreal
Afr
Old Jan 28, 2012 | 12:54 PM
BornSUPERCHARGED's Avatar
BornSUPERCHARGED
I have two of these in my bipod:
http://www.aeroforcetech.com/products_interceptor.html
I can cycle through and view everything. It also reads codes. Displays 4 values at once (2 per)
Old Jan 29, 2012 | 11:22 PM
BLACK-10's Avatar
BLACK-10
Here you go
http://forums.corvetteforum.com/c6-f...l-and-vid.html
I recommend a/f wideband and FP foremost.
Old Jan 29, 2012 | 11:50 PM
FireRescue's Avatar
FireRescue
Thanks to all that have replied. I have a good idea now as to what direction I need to go.
Detoxx03's Avatar
Detoxx03
I recommend getting a air/fuel gauge.
Old Jan 30, 2012 | 12:54 PM
JSB LS3's Avatar
JSB LS3
Wide band A/F, fuel pressure, boost...
Old Jan 30, 2012 | 01:40 PM
DSteck's Avatar
DSteck
If you already have a boost gauge, get a fuel pressure gauge. It's more useful than a wideband IMO.
That said, I run a boost/vac, fuel pressure, and wideband.
Old Jan 30, 2012 | 11:56 PM
BLACK-10's Avatar
BLACK-10
If you run methanol wideband is a must have imo
Old Jan 31, 2012 | 08:50 AM
KBG's Avatar
KBG
Make sure you get a WIDEBAND air/fuel gauge and not just an air/fuel gauge as they are little more than a pretty light show
Old Feb 14, 2012 | 02:00 AM
BLACK-10's Avatar
BLACK-10
This video show AEM wb/af, fuel pressure and boost/vacuum
To Gauges
