C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Another one bites the dust
Old Feb 9, 2012 | 06:26 PM
  #81
Unreal's Avatar
Unreal
So far that is the plan. Still waiting to hear back on more numbers and stuff. Vengance called back and left a message. At least they followed up 4 days later.
Current Plan
5.3L Gen IV Block
Livernois Darton Sleeves 4.125"
Callies Dragon Slayer
Callies Billet Ultra I-beam Rods
Livernois/Diamond Coated 9.7:1 Pistons
ARP 1/2" Head Studs
ARP mains
Callies Billet Mains
Vortech Ysi
ECS Fuel System
Cam and Lifters ????
Reuse my TSP 285CC heads, etc. Nothing has been ordered so it is all subject to change.
Old Feb 10, 2012 | 08:41 PM
  #82
Unreal's Avatar
Unreal
Just looks like a bad lifter. Cam stuff was all tight. All the lifters cam right out. The one with the broken tip I just pushed down so it didn't damage the bore. Pistons, valves, etc all look great. Pictures added
Old Feb 10, 2012 | 09:19 PM
  #83
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
So what's the plan now? Still a rebuild?
Old Feb 10, 2012 | 09:23 PM
  #84
Unreal's Avatar
Unreal
I'm not 100% sure. Needs a new cam and lifters for sure. I need to lift the motor out to pull the pan off and get the broken piece of lifter out of the pan. If the motor is coming out it is at least getting pistons. The plan is either throw some Diamond 9.7:1 pistons, new cam, new bearings, arp mains, arp rod bolts, etc in it and reuse the stock block/crank/rods. Or option two is sell the short block as is, and build an LSX block with all high end stuff. Leaning towards option 2 but need to find a buyer for my short block.
Old Feb 10, 2012 | 09:28 PM
  #85
JUIC3D's Avatar
JUIC3D
I vote option 2. Was there any damage to the block?
Old Feb 10, 2012 | 09:34 PM
  #86
Unreal's Avatar
Unreal
Nope. Block looks fine. Everything in good shape. I too vote option 2 which would include upgrading to a Ysi, fuel system, etc.
I'll get the motor out tomorrow to double check it and see.
Old Feb 10, 2012 | 09:36 PM
  #87
JUIC3D's Avatar
JUIC3D
Might be interested in the shortblock depending on price. Let me know what you decide.
Old Feb 11, 2012 | 10:24 AM
  #88
Unreal's Avatar
Unreal
Interesting. Just busted out the calipers and inspected everything. The pin on the comp cam was oversized causing the cam gear to stick on it. When torqueing the bolts to 18 ft-lbs it never got flush to the cam surface because it got stuck on the pin. That caused excessive thrust which killed the lifter. The cam gear slides on easy to the stock cam and sits nice and flush.
Old Feb 11, 2012 | 10:32 AM
  #89
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
give comp a call, they are pretty good about fixing obvious mistakes like that. maybe you'll get a free set of lifters with a free cam?
-Carl
Old Feb 11, 2012 | 10:36 AM
  #90
JUIC3D's Avatar
JUIC3D
Wow, that's nuts. It makes sense though. My car gear slid on the end of my cam with no resistance, but that's a bummer about yours.
I'm curious if comp can do anything about it.
Old Feb 11, 2012 | 03:30 PM
  #91
3 Z06ZR1's Avatar
3 Z06ZR1
You think that would have noticed on assembly!
Old Feb 11, 2012 | 05:32 PM
  #92
DSOMC6's Avatar
DSOMC6
Originally Posted by DSteck
Talk to the guy I mentioned. He said even if the lifter bore is damaged, it can be fixed.
Dsteck, I will call him once I know the damage to the current block/setup. That is what will determine the route I go.
Hoping to hear back from a few of the other shops today. So far nothing from any of them.
Jesel bronze inserts. Most big HP engines utilize them
http://www.jesel.com/innovation/lift...retainers.html
Old Feb 11, 2012 | 05:49 PM
  #93
DSOMC6's Avatar
DSOMC6
Ugghh! If that's truely the cause I would send it back, ask for a refund, and call it a day.
I quit purchasing Comp products a while back. Thier quality has been sub par in the past and more so in the recent past (bad batch of springs and lifter problems) and this to me confirms it still is an issue.
Old Feb 11, 2012 | 07:00 PM
  #94
Unreal's Avatar
Unreal
Lifter bore is fine. Lifter didn't spin or anything, just lose the tip and beat up the cam. Motor is almost out but I have no help to pull it right now so I maybe done for the day. Already got 3-4 phone calls locally of people wanting the motor.
Old Feb 11, 2012 | 07:01 PM
  #95
Unreal's Avatar
Unreal
I agree. Then again the bolts torqued to 18 ft/lbs and you wouldn't notice just by looking. I never thought of grabbing the cam and seeing if it wiggled. Never had an issue before.
