C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Ecs!
Old Mar 6, 2012 | 08:21 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
Default Ecs!
I love the new website!
-Carl
Old Mar 6, 2012 | 09:06 PM
LB's Avatar
LB
ordered my alternator relocation kit. worked great for me
Old Mar 6, 2012 | 09:22 PM
ZBADESTZ@Straightline's Avatar
X2
Old Mar 7, 2012 | 09:14 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Thanks guys!! Tons of time went into it, and we are not even half way finished loading product and other features yet so keep an eye on it!!
Old Mar 7, 2012 | 10:26 AM
Matt @ ECS's Avatar
0Matt @ ECS
Former Vendor
Ugh.. He's right
I'm going to be adding a ton more products. This is a great start to jump-off with the new website because let's face it, the old one needed an update for a while!
Old Mar 14, 2012 | 09:58 PM
carlrx7's Avatar
carlrx7
Can you guys post the Torque Tamer Install instructions?
Old Mar 15, 2012 | 09:58 AM
Chris@East Coast Supercharging's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Hi Carl, here is a pic of it installed in the tunnel area
What you do is bolt the torque tamer up with 2 bolts to hold it in place. You then will take the factory tunnel plate or aftermarket if thats what you are going to use and place it up in the tunnel area. You need to mark where they will over lap and then cut that area off the tunnel plate so they will be sitting next to each other. I would leave about 1/4" of room between them when they are bolted up so they wont be able to touch and make noise. With the torque tamer strap bolted up you need to just snug it up well over the top of the torque tube. It does not need to be really tight, just enough to keep the torque tube from being able to flex up on a heavy launch..
Any questions just let me know..
Old Mar 21, 2012 | 07:01 AM
BoosTTed C6's Avatar
BoosTTed C6
Matt, please log Chris off when he runs out to the Plumstead Grill because the above is proof that Doug must be posting on Chris's account. I didn't think Chris knew where the garage was let alone possess the technical knowledge to install something other than lunch.
See you guys in two weeks (unless Chris is going to get spiteful and erase my name)...
Old Apr 13, 2012 | 04:41 PM
carlrx7's Avatar
carlrx7
btw, make sure that the loop does not go over the shifter linkage,FML, p.s. i cant "shimmy" the loop around with out dropping the subframe.
p.s. what are these peices for? circled in red,
Old Apr 13, 2012 | 09:21 PM
carlrx7's Avatar
carlrx7
bump,
Chris, can you post pictures of the c5 and c6 half shaft safety loops? I think I may have gotten the c5 ones.
To Ecs!
