Has anyone used a 3.25 pulley on an E-force ls2 without a cam? How much boost can I expect to see with 1.7/8" headers, xpipe w/cats and a 3.25 pulley?
Will a blower cam add boost or subtract it?
I have basically the same setup you are describing. With the 3.5 pulley I was making about 7lbs of boost but adding the headers dropped it to about 5.5
I am putting a 3.25 now to get the boost back and will try and get to the tuner next week. I can tell you the number after I get there.
I have the E-Force on my LS2 with the 3.25" pulley. Altitude does effect boost. My last data log taken at Bandimere Speedway (5,800') logged max kPa of 144 @ 6,300 rpm. The DA for this run was 8,400' (144 kPa X .1450377377) = 20.89 psi - 10.75 psi for a DA of 8,400' = 10.14 lbs of boost created at 6,300 rpm with a DA of 8,400'.
Maybe I misunderstood what was asked. Of course altitude effects boost. I was just saying that for me, being near sea level altitude is not an issue. Is my understanding right that at higher levels you get less boost from the same setup? I will have to see how much I get with the 3.25 because I really dont want more than around 8 lbs. According to your data I may end up with too much.
That info is dead on what I had before adding headers. Right near 7.5 lbs with the 3.5 pulley. I'm guessing I will gain back the 2 I lost by going 3.25.
realcanuk, My boost readings are based on a calculation and not actual boost read by a boost gauge. Edelbrock states that their 3.25" pulley creates 9.5 lbs of boost at sea level. My guess is you will create more than 8.5 lbs of boost with the 3.25" pulley. Remember, the boost I registered of 10.14 lbs was only for a fraction of a second at maximum/peak rpm.
I have a TVS2300 on my LS3 with mild blower cam, bolt ons, and 3.3" pulley. About 100' above sea level. Sees around 9psi. Also have a 6.0L equipped similarly with a 3.1" pulley. It sees 12psi. I'd bet a stock LS2 with headers and 3.25" pulley would see in excess of 10psi unless the intake was really restrictive. Good air cleaner/intake is pretty important with these blowers. I picked up an additional pound and a half of boost by putting a much bigger air filter on my 6.0L.
I will know next week but I think edelbrocks number are on an othewise stock engine because my max boost (on the dyno) was very near to what they state. Like I said, adding headers cost me 2 lbs so I expect to be near my goal of 7-8 area, which is what I started with.
I dont see how going 1 size smaller pulley will add 5 lbs but, I will see next week and update this thread with my findings.
realcanuk, your 1 7/8" headers will make a difference in your ability to create boost. I have 1 3/4" Kooks long tubes. Are your boost readings taken with a boost gauge or a calculation using kPa. If a calculation, are you using density altitude (DA) or elevation above sea level (14.7 psi @ sea level).
Keep us posted, I also have 1 7/8 headers and 3.5" pulley and my boost reads around 7 lbs max (I don't have a gauge that holds the max reading so this is by eye). It looks like I only lost about 1/2 lb with the headers. I'm interested in how much the 3.25 pulley actually adds to your boost.
I am not sure. They are the numbers off the dyno. I will find out though. The loss of 2 lbs was on the same dyno, same day, before and after headers so however it was measured I know the loss was real.
Keep us posted when you pulley down. I'm going straight for the 3.25 unless it'll put me over 10psi.
Is Edelbrocks intake restrictive as it sits in the kit? Are there other intakes for the E-force out there? will LS9 parts work on this setup?
If all goes well I will be on the dyno next monday and post up the results. I dont think the edelbrock intake is restrictive but I really dont know if there is a better option.
I'm curious I have 1 7/8 headers with 3.5in pulley on my LS3 EForce and on the Dyno I got 6.99 psi at max rpm. So has anyone changed to a 3.25 without changing out the fuel pump. So I figure you pickup top in HP of maybe 50-60 hp but how much medium range torque if any. And would you need to retune the car with adding just a couple psi?
