I cant seem to find any info on starting my car without a tune after I install my E-force. Can I reinstall the stock LS2 inj just to get the car on the trailer? Is this OK if I stay under 2k rpm? I would not install the 60* injectors until it was at the tuner. I was told the 60's would wash down the cylinders and its NOT OK to start with them and no tune.
you can start it and drive it just do not go into boost, and dont put the injectors in yet, it would barely run or not run at all since the computer wont know what injectors are in the car, it's safe to tool around in under 2k rpm till you get the injectors in and the final tune done.
Final tune? I'm talking my bolt-on tune only and I'm just trying to get her on the trailer. This would be cheaper than paying all my buddies in beer to push it on.
its ok to drive it on the trailer, just pop in the injectors while its on the trailer.
oops my bad, was half a sleep then i saw eforce and realized they already have injectors in them, note to self.. dont try to read when i am this sleepy.
If you only plan to run the car for 30 seconds to get it on the trailer I'd say just fire it up and go for it. Without a proper calibration it's going to run like crap whether you have the stock injectors or 60lb injectors in anyhow.
