I just added the ECS Meth kit and a 102 FAST intake to my 2006 SC C6. While determining how to orient the intake pipe, I have been considering deleting the MAS and going with a Speed Density Tune (separate IAT and 2 bar MAP). The tuner I use in Houston (LMR) is excellent and more than capable of doing this tune.
I have read that with the 2006 C6 you can’t go SD due to the lack of VE tables in the OS. Is this true? Can I run SD?
You won't have a problem. I've had SD tunes on older than '06's. Confirm with LMR. I'm guessing they will know
