ZR1 (MH3) TR6060 conversion $2,695
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
We are offering any TR6060 conversion to ZR1 ratios for $2,695. This conversion will be with ALL new gears (4615 metal) and will include new gasket. New synchronizers will be additional if needed. Carbon blockers (1-4 gears) will be additional ($600). Bronze fork pads (1-6) also available.
We also offer custom over drives for your MM6 and MZ6 TR6060. You can have .80/.63 on MM6 or .74/.50 on MZ6 or any combination (.80/.50 on MM6 for tight 1-5 and steep 6th overdrive). Email me for details and prices. Rick@rkt56.com
Please contact us for details.
Supporting Vendor
First, there isn't any difference between the ZR1 and the base TR6060 regarding the main case. The strength comes from the 9310 metal gears/lower ratios.
would the fact that the Donor trans be a Z51 with cooler impact the price at all?
how much does the Mm6 5/6 add to the price?
also the zr1 tranny is listed as 0.81 5th and 0.67 6th.. any reason the ratios you listed are different?
Supporting Vendor
As long as it's 08 or newer Z51, price would be the same
On the ZR1, .80 and .54 are the only option.
It's actually .82 and .68 but I have listed custom ratios for the MM6 and MZ6 and not the ZR1 ratios.
