C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
EOC with TT Kit?
Old Apr 13, 2012 | 11:48 PM
383's Avatar
383
Photos please, I'm doing this soon and I would like to see what you do for mounts.
Old Apr 14, 2012 | 08:57 AM
Six-Gun-Todd's Avatar
Six-Gun-Todd
Originally Posted by 383
Did you cut the tab off or mount above/below it?
Can I use the stock Z06 EOC lines and cut them then use hose clamps on rubber hoses to make the bend?
Factory lines work perfectly without cutting....
And I'm not certain which tab you fellas are referring to....my setup bolted right to the cradle without interference.
Old Apr 14, 2012 | 09:42 AM
383's Avatar
383
I have mine in a box and haven't even really looked at it yet. I thought it used hard lines for most of the run. Thats great if I don't have to cut it up that thing cost me $400.
I would still like to see what people do for mounts.
Old Apr 14, 2012 | 10:15 AM
AKS Racing's Avatar
AKS Racing
My Z06 EOC looks nothing like that. What is that picture from?
Mine has a larger (taller and wider) cooler, and the lines are hard lines for a bit from the cooler, then go to swaged (no clamps) rubber lines for a fairly short distance, then back to hard lines.
If your cooler looks like what is pictured, with the brackets, it would seem like it would be a bolt on.
My set-up will definitely require brackets be fabed, as the cooler was designed to mount in front of the radiator / condensor package.
Old Apr 14, 2012 | 10:17 AM
383's Avatar
383
Oh sorry, thats my PS cooler. That was a pic for the tab. The EOC is still in a box.
Old Apr 14, 2012 | 10:24 AM
AKS Racing's Avatar
AKS Racing
Is that pic on your car? Are you running a TT?
I will have to deal with the cold side pressure ducts in the general area as well.
It will be a challenge, but if I don't try, I will never know.
Old Apr 14, 2012 | 10:42 AM
383's Avatar
383
No I'm not TT but I want to mount my EOC there. I did not realize your intake tubes took up that much room.
Maybe a pic with a tape measure strategically placed could help, if you have access.
Old Apr 14, 2012 | 04:38 PM
AKS Racing's Avatar
AKS Racing
After much investigation, the Z06 EOC aft of the radiator is a no go for my car. Basically the pimp pump is mounted in the same area and precludes install of the cooler.
I am still looking at other options, but aft of the radiator will not work.
