C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
evap problem
Old Apr 19, 2012 | 08:19 PM
sea six's Avatar
sea six
Default evap problem
I have an 06 LS2. I installed a m112 supercharger a few years ago. I have been getting a code P0455 and a GAS CAP on DIC warning. I have replaced it twice but still have same issue. Is there something in the vacuum lines or a valve that could have gone bad. Car runs great but have a problem with CT emission.
Old Apr 19, 2012 | 09:50 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Need to smoke test the fuel system to locate the leak. Possible purge solnoid stuck on or leaking, Vent valve leaking, Or even a fuel leak somewhere on the tank/lines.
Old Apr 19, 2012 | 09:53 PM
sea six's Avatar
sea six
thanks for information, not syre who does it up here.
Old Apr 19, 2012 | 10:22 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Any GM dealer will have the Evap smoke tester. Make sure they know how to use it so you are not wasting your money on the diag.
Old Apr 21, 2012 | 05:42 PM
Fordracer9's Avatar
Fordracer9
Not going to be a fuel leak. Most likely a vacuum leak in the system. Could be a purge/vent solenoid not quite seating, or a bad o-ring at a connection, or even a kinked line, or a pinhole in a line.
Has this been an issue ever since the blower went on, or something that has just popped up?
Old Apr 21, 2012 | 07:16 PM
sea six's Avatar
sea six
Just what I have been looking for most of this afternoon. I think that it might be the fitting that comes with the m112 that attaches to the bottom of the evac solenoid. It will not seat, seems that the elbow is to short to allow it seat. I hope!
Old Apr 24, 2012 | 12:24 PM
MIGHTYM0USE's Avatar
MIGHTYM0USE
pretty sure i had that code on my tbss and it was the evap solenoid.
here is a link to what part i used.
http://www.tbssowners.com/forums/sho...39&postcount=6
To evap problem
